Question about Motorola Mobility V710
Motorola V710 won't charge
Anyone know a fix for the common problem these phones seem to have? When you plug it in to the charger, it either doesn't see it at all, or tries to charge, then comes back with the error "unable to charge". Is there a way to clean the contact or something?
  • 1 more comment
  • bamm Dec 04, 2007
    my phone says unable to charge when i plug it in to the charger how can i fix it?
  • Anonymous Jan 06, 2008
    v-710 not able to charge by house charger or car charger.Get the error,"not able to charge"When bending the car charger piece closer to the usb charging port,had little success in charging shortly after the battery went completely dead and hasn't been charged since.
  • Anonymous Aug 03, 2008
    Not only is it saying "unable to charge", it keeps flashing on and off and randomly freezing. I'm so sick of Motorola's crappy designing. I've tryed the whole, "clean it with alcohol and scrape it with a needle", its not working.
While not a fix for this problem, what I have found to work nearly every time is to set something slightly heavy on the charger prong where it enters the phone. Turning it over and resting the prong on a book also allows it to make the necessary contact. It has lasted me for two years; one year charging just like that.
Posted on Aug 26, 2008
I had this annoying problem as well. First I cleaned and scrapped the metal prongs with an alcohol pad. Then I plugged it in and pulled on it rather forcefully (but not too hard) until it started charginging. It's charging now but who knows what that means for the future.
Posted on Aug 21, 2008
  • kowla
    kowla Mar 19, 2014
    well my phone is fully charged but it would not come on and it is an t mobile lg phone i dont wont to take it to the shop i wont fix it on my own but how
Try removing the battery and then put it back in. This worked for me.
Posted on Mar 09, 2008
  • 38 Answers
Hi. this is a very common issue with this phones.
one of the charging contacts is disconnected from the main board inside. that's why when a little pressure is applied it tries to charge. but it needs to be checked by some one that deals with that type of phone. a little research and i found someone on eBay that is selling parts for this phone model. so they must know how to deal with it. here is the link V710 Parts
Hope they can help with this issue. but again is very common on this phone model.
Posted on Jan 12, 2008
When i plug my v710 in it says unable to charge how can i fix it
Posted on Dec 04, 2007
  • bamm Dec 04, 2007
    when i plug my v710 in it says unable to charge where do i clean
That's exactly it. Use rubbing alcohol on a q-tip or contact cleaner. Good luck!
Posted on Oct 21, 2007
How do you turn on a motorola v710 after is has charged
push green button and hold on for a couple of seconds.
Jan 03, 2015 | Motorola Mobility V710
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My phone won't charge ?
You really only have two choisces here, the battery is defective or the phone is. The more common issue would be the battery.
Jan 15, 2012 | Motorola Cell Phones
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
I have a Motorola V710, it will not power on but the screen blinks when plugged in to charge, what's wrong?
The batery may not be holding a charge anymore, try removing the battery and clean the contact's, if that do'es not work the battery may need to be replaced.
Apr 18, 2009 | Motorola Mobility V710
V710 Motorola will not power on but screen blinds off & on plg in
I think there is some problem @ your battery. Change the battery & check whether the screen works or not if it ask for unlock code you can get the code from motorola code
Motorola V3 RAZR won't charge!!!
i think due to over charging your cell s capacitor is gone so it not getting charged...
this repairable by replacing capacitor...
so just visit technician................
Feb 11, 2008 | Motorola Mobility RAZR V3
Won´t charge
My SLVR had the same problem, so I bought a new one from Amazon. When I plugged the new one in the first time it did fine, but when I ran the battery completely out, it wouldn't charge. I played around with it a little bit, and I think I've found a solution that works: try taking the SIM card out of the phone, THEN charge it. It works on both my new one and my old one that way. The drawback for you is that you can't use your phone while its charging, I just switch phones while the other is charging, a bit of a pain sometimes, but the SLVR is my favorite phone so its worth it. :-) Good Luck.
Dec 10, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola v710
dear. this is the most common prob with this modle. u have to change u mic.
Mar 20, 2007 | Motorola Mobility V710
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Jun 24, 2006 | Motorola Mobility V710
Motorola Mobility V710 Logo
526 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
