Question about HP Compaq nx6110 Notebook
HP NX6110 with travel battery
Battery #1 is 100% ok,
Battery #2 is 100% ok (travel battery)
When battery #1 go flat, the time remaining disper and there is 55%? back.
Then after a few moments, the computer die.
Reinserting the netadaptor, it show me that #1 is 1% and charging and #2 is 100%.
Here is the $100.000 question :-)
Why doesent #2 kick in when #1 goes flat?
#2 is new.
/Teis
  • Teis Thomsen
    Teis Thomsen Dec 07, 2008
    Everybody says "dead battery"
Hp nx6110 laptop is power lock what is unlockng process
Disconnected the RTC battery will unlock your system. See the steps below.
The more important it is to protect on's data by a DriveLock (which makes the HDD usuable when the password is not available).
Procedure to remove password
(following CPQ MSGs)
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. Half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Warning: All settings are set back to factory standard.
You'll have to enter a correct date/time and change the settings to your needs.
Note: Pls strictly keep to the sequence.
Re-starting with the main battery and or RTC-battery inserted will spoil the job.
Apr 04, 2013 | HP Compaq nx6110 PC Laptop
I need administrator password for compaq nx6110
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
My hp compaqu nx6110 won't hold time amd date what can i do
replace the battery.. the internal battery is dead not the big battery under the unit but a watch battery installed on the motherboard.. i know what you mean i hate dead cmos battery and messes up windows clock and stuff..
Dec 02, 2010 | HP Compaq nx6110 Notebook
How to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Jul 06, 2009 | HP Compaq nx6110 Notebook
Unknown hp power-on password
Did you do all these steps in order?
1) Remove the computer power pack battery. Remove the keyboard.
2) Remove the RTC battery. Wait 5 minutes. (I would wait longer, maybe 15 minutes.)
3) Reinstall the RTC battery. Reinstall the keyboard.
4) Plug the AC power into the computer. (DO NOT INSTALL THE POWER PACK BATTERY AT THIS POINT)
5) Turn on the computer.
This should reset the password and also all CMOS settings.
Jan 26, 2009 | HP Compaq nx6110 Notebook
My pc do not use the travel battery 52wHr
Maybe you buy a second-hand cells Compaq NX6100 notebook battery. The battery usually out of work in 40%. I found many cheap used batteries in ebay. or you
Nov 11, 2008 | HP Compaq nx6110 Notebook
Battery
The battery on this model tends to last between 2 to 4 hrs dependant on use. Does yours only work uoto about 2 hrs or does it sometimes last longer? If the battery is more tham 5 years old it MAY be worth changing.
Jun 19, 2008 | HP Compaq nx6110 Notebook
Battery cant power my nx6110
This is normally caused by a fault either within the battery or the system board. I'd be inclined to take the back off and reseat the board and cables before you start replacing stuff unless you can borrow another battery from somewhere.
May 24, 2008 | HP Compaq nx6310 Notebook
Hp compaq nx6110 wireless problem
Nope - battery is not the problem. Most likely problem is that the wireless radio is using POWER SAVE MODE which shuts it down (or lowers the output power) in times of low network activity to save power. Check in CONTROL PANEL -> SYSTEM -> DEVICES -> NETWORK ADAPTERS -> (wireless card name) - PROPERTIES and then look for an entry in CONFIGURATION and so forth called POWER SAVE and disable it. It might also be controlled through a third party software program running on your machine (something like "Intel wireless configuration" that may also be running in your system tray) - investigate that and look for an entry that says "allow the wireless card to shut down to save power".
Good luck.
Nov 16, 2007 | Compaq NX6110 TFT XGA Notebook
HP Compaq nx6110 Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
