Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
WD my book 320gb not responding
Hi, I used my external hard drive for a year everyday without any problems.
But now it is not responding at all it seams like out of the blue! Not even the light is on and it does not make any noise.
Does anyone know what that means and what i can try to fix it?
I have tried to connect it to several different computers, Mac and PC. The same problem everywhere. Guess that means there is certainly something wrong with the MyBook and not with my laptop. I am am using a MacBook Pro by the way.
desperately need stuff of mybook.  can anyone help please please please? Thanks sophie
  • 1 more comment
  • sophiefriede Nov 22, 2008
    thanks a lot that is good to  know and makes me feel less panic. will try to get hold of some new cables.
    cheers
  • johnlind_sr Dec 01, 2008
    Hi:
    I too have the same problem... the drive was working and then it stopped! no sound, no vibration, no light and noway to open the case to check it out. Boy, would I Iike to get inside the case without breaking it up. I have wondered if the USB connection was not working, cause I realize that you have to have AC current and the USB power from the PC. I have tried to switch the USB cable, but since that made no difference, and since I have 120 volts from the transformer, I wonder if there is an internal circuit breaker inside? Someone out there must know how to fix this thing with out spending $1200 to $2500, [which seems to be the going price to recover the files from a disk].
    Thanks for reading this far...
    John Sr.
  • Anonymous May 03, 2009
    I have the same problem (won't power up - no response at all) but I also have two other identical extenal drives (purchased at the same time) that are working perfectly so I know it's not an internal cable issue. I've tried plugging it into my laptop and it still doesn't work. I've had the drive(s) since late 2007.
    Am I out of luck or is there something I can do without paying an outrageous price for data recovery?
  • 103 Answers
don't panic your hard drive might still be working . you say it dose not sign showing it's on. please have any cable that connect the hard disk to the computer checked. I think your cables might be bad.
thanks
Posted on Nov 21, 2008
I have a WD My Book Essential. I have been trying to format it to be compatible with my ps3 but nothing seems to work. I tried to format as FAT32 but now I have a message saying I have ''no writable disk...
Assuming PS3 works with FAT32, format the hard drive using the WD's FAT 32 formatter. Call WD and they will direct you to the correct download location for your hard drive.
Please rate if helpful.
Thanks
May 16, 2010 | Western Digital My Book Essential Edition...
I have an issue with my external hard drive. The model is WD 320GB Mybook. I've checked the power wire and the usb wire and pretty sure that both are working. I don't hear anything from the driver as I...
I have a similar WD 320GB drive - but it is a Passbook. When I first got it, I set it up and it worked fine. Not liking the very short 12" (.3M) cable, I grabbed a nice 6' (2M) version as a replacement.
I began to have read and write errors on the drive galore. I returned the drive and spoke with a tech person at the store about it. It turns out that the cable supplied is "specific" to a degree for the drive. Use of "any old" replacement USB cable would not work reliably. I found later that I had another 6' cable that worked without a problem. The cable is rather thick when compared to some of the others I have and am assuming that it was a quality issue with my first cable that caused the failures.
Result: Use the original cable if possible. Use a good quality cable if the original is not available (experiment with a few if needed). Of course, if the drive just plain stopped working - and it happens - contact Western Digital tech support for help or replacement if it's still under warranty, or bite the bullet and buy a new one.
I hope this helps & good luck!
Feb 25, 2010 | Western Digital My Book Essential 320GB...
External HDD not detected
have you try with the other usb cable and the usb port.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
Can only see one WD Passport 320GB drive at a time.
This is most likely a classic case of them trying to occupy the same drive letter. If you open disk management Start > Run > type 'diskmgmt.msc' and you should see them both there - One with a drive letter and one without, simply right click on the drive which doesn't have a drive letter and select 'change drive letters and path...'. Change the drive letter to something you know doesn't really get used and they should both appear in my computer.
Hope this solves your problem.
Jan 12, 2010 | Western Digital Passport 320GB External...
External Drive WD is not visible in Mycomputer.
right click on my computer
select manage
then disk management
identify the correct drive
right click and format,
once formatted remove
then plug back in,
you should beable to then see it under my computer
Jul 06, 2009 | Western Digital My Book Essential 320GB...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
Wd my book essential edition hard drive problems
Have you tried running a virus scan on this hard drive. Viruses can pop up in many forms and mess a lot of things up.
Mar 23, 2009 | Western Digital My Book Essential 320GB...
WD my book making faint ticking noises and flashing
it is possibly because the usb port you are connecting to is not receiving enough power to power the hard drive and use it at the same time. try another port or check on another computer else probably have to buy a new one
Sep 11, 2008 | Western Digital 320GB MyBook External USB...
How to open the case of a my book wd 320gb
Try this link:
http://www.ransackery.com/western-digital-mybook-open-case-recover-data.htm
Dec 19, 2007 | Western Digital 320GB MyBook External USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
1,311 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
