Question about KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher
Kitchen aid Dishwasher
I have a Kitchen aid model KUDIO1iLBl5 When it starts to bring water in it sounds terrible. We tore it down as far as we can with nothing looking amiss. I was wondering do you think it could be the water pump. My dishes are still coming clean but I am half afraid to use it for fear its going to seize up.
  • 1 more comment
  • Anonymous Nov 21, 2008
    We have the same issue with the noise as well as very little water coming into the unit
  • Anonymous Mar 21, 2009
    Horrible grinding noise that correlates with the pump. Think something's in the pump. Now that water is in the cellar and on the kitchen floor, I'm buying a duplicate of this old model to cannibalize for repairs. A new motor/pump costs about $170 for the part alone!
  • georgineahma Apr 14, 2009
    I have Kitchenaid dishwasher model Kudio1iLBl5 since 2006 and it never worked properly. Twice I had a Kitchenaid repair man come out to look at the problem (it does not wash the upper rack) and then it worked for a while and now it does not at all. In fact I have the suspicion that the upper water fan does not work but of course I cannot check this while the machine is running!. Surprisingly I bought this model because it was voted at the best model in its class by Consumer Reports. How about that?
  • 49 Answers
SOURCE: Dish machine
you need a plumber sounds like your sink piping has a blockage
Posted on Mar 08, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 530 Answers
SOURCE: kitchen aid dishwasher not cleaning dishes well.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Posted on Oct 18, 2009
Testimonial: "THANKS SO MUCH. WE REALLY HATED WASHING THE DISHES BY HAND. THE CHOPPER HAD FALLEN OFF AND JUST NEEDED TO BE PUT BACK IN ITS PLACE."
ginko
  • 19396 Answers
SOURCE: Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Posted on Apr 08, 2010
Kitchen aid dishwasher not running
Check your breaker or fuse panel first.
Dec 12, 2011 | Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Our kitchen aid dishwasher is about 7 years old, recently it has begun making a high pitched whine while the wash cycle is running. The dishes are still clean, but the noise is new and annoying not to...
Sounds like it could be the bearing in the wash motor. If the sound is only present when you can hear water being thrown around then this would confirm it. Not sure about spares availability on a 7yr old machine though
Jan 18, 2018 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hi.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Not getting any water into the kitchen aid dishwasher
it could be the water inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 04, 2009 | KitchenAid Dishwashers
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
136 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
