Question about Compaq P 50 (White) 15" CRT Monitor
Monitor no high voltage
What is a equivalent of lz174a-304t flyback?
0 characters
1 Points
What is "flyback" on tv monitor
the "flyback" is the VERY high voltage transformer that powers the CRT through a cable that plugs into the CRT inside the monitor case. Don't try unplugging, even with power off, as it has to be discharged to ground to remove risidual voltage, like a capasitor. This voltage is about 35,000 vdc.
Dec 01, 2013 | Samsung SyncMaster 793DF 17" CRT Monitor
What is "flyback" in a tv monitor
A flyback transformer (FBT), also called a line output transformer (LOPT), is a special type of electrical transformer. It was initially designed to generate high voltage sawtooth signals at a relatively high frequency. In modern applications it is used extensively in switched-mode power supplies for both low (3V) and high voltage (over 10 kV) supplies.
this is use only on monitor the old one that used CRT TUBE.
I have LG CRT monitor 17 inch .when i switch on my crt it start sparking sound but not actual spark . the sound was so iritating & sparking shows on screen but not inside the monitor. So what was the...
You have to replace the flyback transformer of your monitor. Its a high voltage stepup tansformer which provides necessory volteges for the picture tube like Anode voltage, screen voltage and focus voltage. After some years of use the insulation stength of the flyback transformer will become bad and the high voltage will try to discharge trough the nearest ground poit. At that time you will hear the sprking sound. Its because of the high voltage Anode volt is discharing to the ground it will reflect on the screen. Using the monitor in this condition will result in the failure of horizontal driver transistor and even the power supply. Replacing the flybalck will solve your problem.
Aug 02, 2011 | LG Studioworks E700S 17" CRT Monitor
My monitor does not display full screen though all the settings are OK. This problem has just emerged recently. The vertical size is fine and the horizontal size is the affected size.REMEMBER ALL THE...
The Horizontal power supply voltage is low. This is provided as a "sawtooth" waveform via the CRT flyback transformer.
Some flybacks offer a voltage adjustment via a potentiometer ("pot") on the side of the unit. I do not have a schematic for your monitor, so I cannot tell you for certain if this is an option. This adjustment should only be made by a trained technician. If you are not familiar with high voltage electronics, DO NOT OPEN THE SET!
I recommend replacing the monitor. When they age, you can only buy some time before it goes for good, and prices are so low now that repairs are not usually cost effective.
Feb 01, 2011 | Daewoo Business 526X (White) 15 in.CRT...
I have a samsung monitor SyncMaster93DF it stopped completly with a little sound (tick tick ) i oppened it and found the hot transistor shorted (st2310) i replaced it with bu2527 because i couldnt find the...
try C5804 or J6812 instead of bu2527..replace IRF630 in 50 volt supply may b if problem after that then flyback transformer may b faulty. repalce it with same one.
Sep 05, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Screan on monitor not lighting up.
How do you know the flyback is good if it is not functioning?
Some causes for no high voltage:
short or open horizontal output transistor.
open or shorted capacitors in horizontal circuit.
Defective or non functioning horizontal drive circuit.
Open yoke.
Malfunction in horizontal B+ regulator circuit.
Faulty solder joints.
Short in CRT.
Apr 26, 2010 | NEC AccuSync 90 19 in.CRT Conventional...
Please tell me what is flyback 1600V working voltage PF (near the horizontal transistor)
Flyback is a step-up transformer multifly the voltage depends on the size of the tube and supplied high voltage to cathode ray tube.The minimum output voltage of this is 14000v DC for 14 inches crt monitor what if your crt is 17 inches 17000v DC very dangerous if you are not electronics repairman.
Jul 14, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor repair
the neck board of the monitor needs tube replace it is corroded with carbon if you cannot get a replacementbuy a new monitor.but also check the flyback also it could be faulty replace it check for your monitor parts or,good luck.
Apr 26, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
No Image
Typical failure is High voltage supply. Can you hear a high pitch whine or the relay click on and off? You will need some test point reffence voltages for the board and confirm you do not have a damaged VGA cable. It is not easy to give step by step via forum. Google "monitor repair", there were a couple good general guides that are printable. If youe high voltage tranformer (flyback) is gone, do not go any further. Price of a monitor flyback is $65 to over $100 depending on model.
Apr 09, 2007 | Acer AC711B 17" CRT Monitor
Compaq P 50 (White) 15" CRT Monitor Logo
Top Compaq Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Computer Monitor Expert? Answer questions, earn points and help others
