Compatability of Memory Upgrade
I had the Memory stick that came with my Acer Aspire T-180 dekstop computer of 512 DDR2 5300 (555mhz) 240 Pin DIMM in the first slot.
I added a 1GB stick of Kybte brand 5300/4200/3200 PC2-667/533/400 240 PIN DIMM (no problems - computer worked fine)
Then I added a generic 1GB stick of PC2-4200 DDR2(533mhz) 240 Pin DIMM (Computer seemed fine for about a month)
Then had the following problems:
1) computer shuts itself off and on quickly at random and slows down considerably to point cannot open word. I replaced my motherboard.
2) When I put the computer back together I had the generic 1GB PC2-4200 stick in first memory slot, the kybte 1GB (5300/4200/3200) stick in the second slot and the factory 512mb (5300) stick in third slot.
Computer seemed to work for a bit and then kept crashing. Reformated entire computer to default factory settings about 5 times then sent back for servicing.
My question: Is it the memory configuration causing my problems or it is a faulty (lemon) computer. I've only had it a few months. Acer E560 compatibility in memory upgrade
  • 859 Answers
DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
Posted on Nov 20, 2008
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I cont play 3d games graphic card is there in acer aspire 4720z
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site :
please rate this advice if it helps
Nov 17, 2010 | Acer Aspire 4720 Notebook
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
ACER Aspire AX1200-U1510A: What mother board and socket is in this computer? AM2, AM2+, or AM3
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
Feb 11, 2010 | Acer Computers & Internet
Acer Aspire One AOA 105-1049 Would like to upgrade memory. What do I need.
your laptop comes with 1g of (DDR2 SDRAM)
( DDR2 SDRAM - 533 MHz SO DIMM 200-pin)
so you will need any
DDR2 SDRAM - 533 MHz SO DIMM 200-pin ram.
the pin is very important. and it has to be notebook ram.
how ever the bad news is your laptop bored will only support going up to 1.5g
so sticking a 512mb in your gona lose part of it, as well you take the chance of making your system unstable. Below is a link of what your looking for.
for the added performance on updating your ram your not going to get your money worth. I just recommend saving your money.
please rate this and mark it fixya if it has helped.
Nov 27, 2009 | Acer Aspire One A150-1049 Notebook
Acer Aspire Memory problem
check hardware compatability,vista is touchy,get xp
Sep 23, 2009 | Acer Aspire 5315 Notebook
One or both of your RAMs have developed a fault. Change both RAM. After changing RAM pl format again and than try. Do not insert those faulty RAM again. Get your RAM tested by a software which is available on Microsoft site for free.
Jun 04, 2008 | Acer Aspire™ T180 PC Desktop
RAM ON acer computers
Yes... just need to purchase the right stuff.
You need to determine if you have DDR or DDRII. And then determine if you have one stick of 512, or if you have 2 sticks of 256. Once you know this information, visit your local Best Buy or purchase somewhere online, a memory upgrade. Such as 2 sticks at 512mb for 1 gig total. Assuming you have two memory slots, should have anyway.
DDRII is fairly cheap right now, be a good time to upgrade. DDR on the other hand, is still a little more expensive.
Oct 30, 2007 | Acer Aspire 3680 Laptop
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
