Question about Kenmore Elite 45986 Front Load Washer
My washer doesn't open...
My washer (Kenmore elite) doesn't open and I have laundry inside it. Can someone help me?
  • 2 more comments
  • Anonymous Nov 26, 2007
    my washer won't open and the drain and spin won't spin.
  • moonbeam3113 Jan 06, 2008
    I have a load of laundry in my washer-right before the end of its cycle it started a Fdl error, I tryed the drain and rinse but it still says fdl and it will not let me open the door.
  • doundaw Jan 25, 2008
    I have been having similar problem when I try to use the delay cycle within minutes the machine beeps and flashes F70 then will beep again and the machine shuts itself off with door remaining in lock position. When I restart the machine it runs for a few minutes and shuts itself off. Its the HE5t but last years model we bought the display and only received it approx. 2 weeks.
  • joellenNC Jan 24, 2009
    I have loaded my laundry and tried to run the load but I get the FDL code, I hear the 6 click when the washing machine tries to lock, actually that is when the FDL code appears. The machine thinks it can't lock; but actually it is. I have taken the bottom panel off and manually unlocked the machine. That has not helped the problem. Any ideas what I have to replace and how to get at it??? I REALLY NEED TO GET THIS FIXED. Thanks everyone.
I am having the same problem.. Was wondering if you have found a solution, If you did can you please pass it along?
Thanks,
Tianak
Posted on Jan 07, 2008
The instruction manual suggests running the "drain & spin" cycle, because there is most likely water left in the machine.
Posted on Feb 16, 2007
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
Dec 18, 2017 | Washing Machines
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
We have a Kenmore Elite front loader and yesterday while washing a load of laundry, the lights flickered and then the machine turned off. I checked all the breakers, unplugged and replugged and nothing...
There is a pull tab at the bottom of the door latch assembly that can be used as a manual release for the door by pulling it down.
Lean the washer backwards and unscrew the 3 screws under the bottom edge on the front of the washer to remove the lower panel under the door. Once the panel is removed, reach the tab with your hand up inside the washer behind the front casing on the right side and pull it down. The door will open.
If there is an error prior to the jamming of the door, the door latch assembly must be replaced. Feel free to let me know if that is the case.
Dec 01, 2009 | Kenmore Elite 45986 Front Load Washer
What is code f70? washer wont start.
According to the Whirlpool cabrio / oasis manual
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} (F70)
Overloaded
oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity.
• Open the door lid to clear display, remove excess laundry, then restart the cycle.
Sep 27, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
Kenmore elite h4 front load washer throwing error code ''f' During middle of cycle i have to push pause and cancle and drain and spin to get it to work
I just fixed this problem in my kenmore washer today. You need to take out the three small screws on the bottom of the front panel. You will need a star shaped screw driver. The panel will fall off when the last screw is removed. After taking off the panel, you will see a large round piece in the middle that should be white; take this piece and turn it to remove the filter. Your filter is most likely clogged with small laundry items or lint and dirt. Remove the blockage and the washer will work great again. This is frustrating, so my wife and I are going out to buy some netting bags for washing small items. Make sure you have a towel under the drain before you open it.
Before doing this though, take a second and reach up under the rubber gasket that circles the inside of the washer door. Your blockage could just be in this area. Our washer had both areas blocked.
Hope this helps
May 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
