Question about Saeco Royal Professional Espresso Machine
Dregdrawer. miss. My Saeco Royale cappucino machine says dregdrawer missing after I emptied it. Its there, but not sensing it! Help!
  • 4 Answers
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Posted on Nov 22, 2008
Dregdrawer missing message won't go away
The dregdrawer is connected to a button/switch inside the machine.
- Switch broken.
- dregdrawer wrongly placed.
- dregdrawer is broken. (projection which goes into te machine is broken)
Sep 29, 2014 | Gaggia Titanium Espresso Machine
Brew unit missing
the BREW UNIT is this part of the machine wich is behind the right side door.Take off the dregdrawer open the door,and you will see handle to grab his hand, then press the "press" and pulling the unit.Then put it back in place and must be done. If you have any questions, write me!
Dec 30, 2013 | Saeco Magic Comfort Plus Espresso Machine
I have a red light and nothing is working no cofee and no milk nothing
I have a Saeco Easy. Maybe the solution for my machine will help you. You did not specify which light is red I will assume it is the "Alarm" light.
Alarm light (looks like an "!" exclamation point)
• permanently on: signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full.
• slowly flashing: signals that the brew group is not inserted, the dregdrawer
is not inserted, the coffee bean hopper lid is not on, the service door is open
or the steam/hot water knob is not correctly turned to the desired position.
• quickly flashing: signals the need to prime the water circuit
Apr 19, 2011 | Saeco Talea Giro Espresso Machine
How do i empty the dregdrawer on a saeco incanto de luxe? I am seeing the DREGDRAWER FULL message and cannot get out of it.
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn't know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds.
Jan 02, 2011 | Saeco INCANTO DELUXE Espresso Machine
Saeco Espresso Machine Dregdrawer indicator light is on and machine does not brewing a coffe
make sure you empty the dregdrawer only if the machine is turned on, otherwise it will not count it as emptied.
Dec 26, 2010 | Saeco Odea Go
I have a new machine where the Dregdraw Miss is displayed although the drawer is in place. any idea what the problem may be?
When you pull out the dregdraw you will see a small lug on the side which engaged the micro switch in the machine. Now use a small screwdriver or toothpick and push in the switch to see if itis working.
If it's still working you have to adjust the lug on the dregdraw by heating the plastic and pulling out a bit to engage the switch.
It can happen in the new machine.
Jul 27, 2010 | Saeco Royal Professional Espresso Machine
I have a saeco roayl professional espresso machine
Check behind the drawer, there might be some grinds preventing the it from activing the microswitch.
Jan 25, 2010 | Saeco Royal Professional Espresso Machine
Error message: Dregdraw miss
which machine do you have. The drawer is not hitting the micro-switch try puttin a piece or 2 of tape on the tab on the side of the dredge drawer
Nov 20, 2009 | Saeco Coffee Makers & Espresso Machines
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Saeco Royal Professional Espresso Machine Logo
2,360 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
