Question about Sub-Zero 680 / S
Sub-Zero 680 - Service light flashing/need to change the filter
I have a Sub Zero 680 refrigerator. The water and ice tastes weird andmy guess is that you need to change the filter, but the problem is,where is the filter and how can I change it?
Also the Service text is flashing on the LCD panel, what does that mean?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The service flashing means that you had a long run time over a period of time. You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that will clear the fault code. If it comes back you have a problem that needs to be addressed such as cleaining the condensor. There is no factory filter on these units. If there is a filter it is most likely under the unit, which can be accessed by removing the kick. THe kick plate is held in place by two phillips head screws, remove them and have a look. If it was done by a "professional" they should have put an inline shut off valve for easy replacement of the filter.
Posted on Dec 06, 2008
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
Our Sub-Zero Mdl 680F is 11 years old, and virtually for its entire existence in our house, the water and ice dispenser has been un-useable because they taste bad. The taste was "oily" almost as...
Hello
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Replace the water filter cartridge in your refrigerator if the ice tastes bad or the control center display recommends it.
Sep 07, 2011 | Sub-Zero 680 / F
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
Why does my ice taste bad? Is there a filter for my ice maker?
Oct 25, 2010 | Sub-Zero 632 / S
My sub-zero 650 top refrigerator/bottom freezer produces ice that has a petroleum, chemical taste and smell. What is the cause?
ck the water supply line . if plastic this may be the problem. all plastic line is not water quality . . also the 650 do not have a water filter . install a after market inline filter . / carbon tybe for taste . .. mm
Sep 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 650S with bottom freezer-Ice tastes funny(musty ? taste)
The 650 does not have a filter built into the unit. Any filter would be on the supply line to unit, usually in the basement below the unit, or under the kitchen sink. Do you use alot of ice? If not you may want to empty the bucket every few weeks to let it produce fresh ice.
Jul 21, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Water Tastes Funny From Sub Zero Dispenser
It will take about three to four months of using it before the plastic loses it freshness into your water. It has to dissipate the "New Car/Plumbing Smell" so to speak. It.s a normal unpleasant necessity but on the bright side... it does go away with use.
Sep 18, 2017 | Sub-Zero 685/S Stainless Steel Side by...
Refrigerator Model FR23W3aw0 Frigidaire
cant bring up that model # there in the refrigertor side top right... in rouund like the fliter, plastic case most filters usually just turn counter clockwise to come off
Sep 03, 2007 | Sub-Zero 680 / S
Refrigerators Logo
3,123 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
