Question about Sony FD Trinitron WEGA KV-13FS100 13" TV
Channels scroll quickly and can't be stopped
This is a 4 yr old Sony KV-13FS100. The channels on the screeen display cycle through on their own. The reote is inoperative, and the channel buttons on the tv do not work. I have unplugged the set and plugged it back in without resolution. Help
2 Suggested Answers
  • 19396 Answers
SOURCE: Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Posted on Apr 12, 2008
I also have a Sony Trinitron model KV-13FS100 (chassis BA6, mfg July 2002) which is experiencing the same problems. I have made the checks suggested by pauldonp above. The channels cycle 1,2,3,4,5 etc. The remote has no effect. The channel up/dwn buttons on the TV have no effect. However when I press volume up or volume down on the TV it stops the channels from cycling for a moment before they continue again. Any help would be greatly appreciated.
Posted on Dec 04, 2008
0 characters
1 Points
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Standard (CRT) Televisions
I have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
All Freeview channels need re-tuned after 30th September.
To re-tune your Sony TV...
1.Press Menu button then go to settings...
2.Scroll down the menu icons until you get to 'Digital Set-up'
3.Press enter/centre key next to direction arrows
4. Select spanner icon and digital audio tuning.
5. You will then be asked if you want to start digital audio tuning.
6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Lost channels on a Sony KV-1972R
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
Jan 18, 2009 | Standard (CRT) Televisions
Sony trinatron has no menu control, can't auto add channels
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony TV Trinitron
I think you have K5 model, if so, replace the all the control switches under the tube, inside the flap.There are three columns of two switches.
Nov 09, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-13FS100 13" TV Logo
43 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
