Question about APC Back-UPS XS900 (BX900) UPS System
Warning sound come on
I was away for 4 days, came home and the warning nose was on. if i shut the system off, then turn it on, it seems to reset and all is normal. but then after an amount of time, the warning sound comes on again.
the system has been less then year.
  • 31 Answers
Most if not all units come with a one year warranty. If you bought yours used check the serial number with APC to see if your unit is under warranty. If it is they will send you a new or refurbished one. They have decent customer service and ship pretty fast. Is that warning noise illuminating the replace battery led? If so you may need a new battery especially if it is over a couple of years old. It is cheaper in most cases to get a higher capacity third party battery and replace it yourself then to buy a new ups. Unless yours is not functioning properly or you need a higher capacity unit. Just recycle the batteries and sell the unit if you upgrade.
Posted on Nov 21, 2008
  • Radiorara Nov 21, 2008
    Another solution would be to download the manual for your ups unit. There are corrective actions that you can do as listed in their pdf files. You can lower the sensitivity of some of the ups units so they are not going to battery power as frequently and this will extend the life of your ups. If your incoming power is "dirty" then consider buying a voltage regulator such as the apc 1200R and putting it between your ups and the wall. These voltage regulators are better than most ups's that include avr protection and this will prevent the ups from errors and constantly coming on and buzzing as you are supplying clean power to the unit. I have a few of these setups and they work flawlessly even with older apc units like the backups280 and 800 RT. The true advantage is being preventative and not having to spend hard earned money replacing expensive computer and video equipment and the hassle of downtime.
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Tyre Pressure and ABS
By operating the tire pressure warning system reset switch, tire pressure warning system ECU can be set to issue a warning at an inflation pressure that corresponds with the type of tires.
Operate the tire pressure warning system reset switch only after the inflation pressures of all 4 tires have been adjusted on the vehicle.
To initialize the system, press and hold the tire pressure warning system reset switch for 3 seconds or longer with the power switch turned IG-ON. When starting the initialization, the tire pressure warning light blinks 3 times at 0.5 Hz.
During the initialization, the tire pressure warning system valve & transmitter measures the inflation
pressure of the tires, and registers the signals that are transmitted into the ECU at a frequency of 1 per
minute. The initialization process is completed when the signals from the tires have been received.
Once the tire pressure warning system reset switch has been pressed, do not turn the Ignition switch OFF for a few minutes.
Mar 05, 2014 | 2002 Toyota Corolla
I have a 2005 ford Taurus the other day warning lights came on saying check traction system then warning light came on saying check break system I pulled into my driveway turned the car off and it would...
You either have a short/large draw in your electrical system or your alternator is bad. Remove the alternator and have it tested at your local parts store.
May 22, 2017 | 2005 Ford Taurus
My child away at college, has a Rav4, 2008 with a warning light on that looks like "tire tread?" Just had the oil changed 2 weeks ago, so shouldn't have anything to do with that. Sound familiar?...
That symbol (tire tread) could mean a low tire pressure. The majority of vehicles today have the low tire pressure warning system, which indicates that one or more of the tires are below the minimum tire pressure. Have the tire pressure checked in each tire. As for turning the warning light off, some vehicles the light will go out after tires are inflated properly. Have them check the owner's manual for resetting warning light. Please inform me as to whether or not it was the tires...thanks.
Nov 14, 2010 | 2008 Toyota RAV4
On a 2001 ford taurus what is the exclamatin point on the dash? The light comes on and goes off at times.
Hope this helps.
Item Part Number Description 1 — Instrument cluster 2 — Odometer reset shaft 3 — Air bag warning indicator 4 — RH turn signal indicator 5 — Charging system warning indicator 6 — Tachometer 7 — Low oil pressure warning indicator 8 — Brake system warning indicator 9 — Cruise control indicator 10 — Check fuel cap indicator 11 — Anti-lock brake system (ABS) warning indicator 12 — Check transmission indicator 13 — Odometer 14 — Transmission range selector indicator 15 — Trip odometer 16 — Theft indicator 17 — Low coolant indicator (if equipped) 18 — Safety belt warning indicator 19 — Low fuel warning indicator 20 — Fuel gauge 21 — Malfunction indicator lamp (MIL) 22 — Door ajar warning indicator 23 — Traction control indicator (if equipped) 24 — Engine coolant temperature gauge 25 — High beam indicator 26 — LH turn signal indicator 27 — Speedometer
Jun 05, 2010 | 2001 Ford Taurus
Engine Life Warning Light Reset
disconnect the battery cable for 3 minutes
Jan 01, 2009 | 2000 Lincoln LS
Service Stability System keeps coming up on my display. It seems to do it right after starting my car and backing up or when coming to a stop sign. The other day I backed out of an area kind of quickly due...
I had the same problem...but I found out that the dealer had rotated incorrectly the tires.
Front and back are different sizes and if a rotation is performent front to rear, you may get a stability light warning.
I corrected my tires and the warning went a way.
Jul 17, 2008 | 2004 Cadillac SRX
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
APC Back-UPS XS900 (BX900) UPS System Logo
419 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
