Question about Dell Dimension 2400 PC Desktop
Keyboard I have problem with my keyboard where I cant get any response when i press any keys (only beep sound). I tried using the same keyboard in another PC and its working well. As the keyboard im using is PS2, i tried using USB, still the same. I thot of checking out the BIOS setting as it might have chnged, but I cant enter to BIOS as the keyboard is not responding. How can i resolve this problem...please help..
  • Deepa Barathy
    Deepa Barathy Nov 20, 2008
    Sorry, but what do you meant by check the system? Where, in which part?..But anyway thanks
  • 849 Answers
Not problem with keybaord, check ur system.
Posted on Nov 20, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Keyboard beeps when any key is pressed eventhough all sticky key and filter key is turned off
    get a cheap usb keyboard, plug it in and see if same issue shows
    if it does, your keyboard on laptop is shot
    if the usb keyboard does same thing, it's a more major issue on motherboard
    anything spill on this unit by chance?
    Jun 13, 2012 | MSI Computers & Internet
    Won't makes a sound when pressing on keys. I
    you may need a new keyboard,, the beeping sound when pushing keys means there is a sticky key [bad keyboard]
    I dont know what option you changed for the keyboard speed? try changing it back..
    May 16, 2010 | HP Pavilion dv6000z Notebook
    The continuous beep sound after power on bios
    Your keyboard keys are stucked try to clean it and set your BIOS setup to default, that way your system will accept any changes you've made or added.
    Oct 21, 2009 | Acer Extensa 4620 Notebook
    The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
    May 28, 2009 | Gateway 2520915 Keyboard
    Beep noise during booting and no keyboard response
    Sounds like the key is stuck. You will have to remove the keypad to check the switch underneath.
    Mar 14, 2009 | Dell Latitude D800 Notebook
    Pressing keys on keyboard produces beeping sound but does not type
    Can you try this keyboard on another computer or another keyboard on this computer to isolate the problem
    Mar 07, 2009 | Gateway 2520915 Keyboard
    Keys doesnt work
    ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
    Nov 14, 2008 | Acer Aspire 4520-5582 Notebook
    I found out what was wrong in my case. Someone had tampered with the accessibility options
    So for anyone with keyboard problem check :
    In Windows XP : control panel-> accessibility options -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
    In Windows Vista : Ease of access -> Ease of access center -> keyboard : StickyKeys and Filterkeys checkboxes should be unchecked.
    Jun 25, 2007 | Gateway 2520915 Keyboard
    Dell Dimension 2400 PC Desktop Logo
    41 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
