Question about Acer Aspire 5600 Series 5630-6951 Laptop
When connected on Skype orbicam will not open
The orbicam does work on its own
Message says that it is already open in another application
Incoming video is displayedOK
    Problem Solver:
  • 14 Answers
Look at your active programs and see if any are connected to the orbicam. Try closing all applications except for skype. Check your active services to see if any of those may be using the cam.
Best of luck
Posted on Nov 22, 2008
    Problem Solver:
  • 72 Answers
Reinstall driver. if same problem occur. reformat PC.
My orbicam is not working
You should go online and download the updated Driver for the orbicam (google on orbicam). Reinstall it, restart the computer, and then try the cam again. There may be something in Skype that helps config your cam.
Aug 28, 2009 | Acer Aspire 5050-3242 Notebook
Acer Orbicam does not work anymore
Sounds like a driver went astray.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 07, 2009 | Acer Aspire 5610-4648 Notebook
Orbicam freezing in Skype
click right button on minimizes and maximize and c what happens
Jun 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
1. Check if your computer has enough memory available. Open task manager, select performance tab. Check the green bar on the bottom then copare memory usage to the total of your Physical memory. If your usage is greater then physical memory then upgrade memory on your laptop.
2. Unistall your Skype application and reinstall it. Do the same for your Webcam.
Good luck.
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Acer orbi cam not working
Checked if your orbicam is in device manager (under imaging device),
if it still there, you might have wrong orbicam application installed. try to download the orbicam application, there are 3 type of orbicam for Aspire 5050 (suyin, bison and logitech). try to installed one by one.
or if you can try to reload the whole windows, using alt+f10 during boot.
Feb 18, 2008 | Acer Aspire 5050-3242 Notebook
Webcam not working
Hi speed USB Device attached to non Hi Speed Hub.... this message appears because the USB hub controller is not updated. Try to download USB 2 driver from the following. http://www.softwarepatch.com/tips/usb2-driver.html
Another application already using webcam--- for this error message... try this.. right click my computer. Properties-> hardware tab. -> device manager. check any abnormal marks like a yellow circle or yellow question marks in the cam . also check the COM ports.
Dec 29, 2007 | Microsoft Office Outlook 2003 for PC
Acer Aspire 5600 Series 5630-6951 Laptop Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
