Question about Tappan TGF363 Gas Kitchen Range
Tappan TGFS26C, Oven igniter not even
Tappan Model # TGFS26C, I have to turn on stove top with a lighter because I guess pilots are not working, Oven doesn’t even come on. I check the oven igniter and it isn’t glowing, I do not even smell any gas in the oven. Would you tell me how to fix these 2 problems? Thanks
  • 108 Answers
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Posted on Nov 22, 2008
I have a tappan gas stove. the stove top works but the oven doesn't heat up enough to cook and i can smell gas. I checked the gas line and it is tight with no leaks. i am wondering what could it be and...
You could do the repair yourself. Much more information is needed. Is your oven spark ignition or hot surface ignition ? A valve may be opening only partially. This can happen on a hot surface ignition system when the glow bar is starting to malfunction. Need to know more details to be of real help.
Tom
Aug 10, 2010 | Tappan TGFS26C Gas Kitchen Range
The top burners work on my stove but the oven wont turn on any solutions
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 15, 2010 | Tappan TGFS26C Gas Kitchen Range
Oven/Broiler doesn't work. Stove top works
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | Tappan TGFS26C Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
556 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
