Question about Philips Magnavox 27MS343S 27" TV
My tv sound ok, crt high voltage ok,channel number display ok
But no display for picture. what reason,tell me
  • 67 Answers
Check for a resistor rated around 220kohms somewhere around the flyback area. i have never worked on this model tv before so i cant give you an exact part number on the board but had the same problem with sharp tvs
Posted on Nov 21, 2008
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
Sound but NO picture
Hello ashleewith2e,
This sounds like a high voltage problem or a picture tube issue (burnt out filament). I would first determine if you had high voltage at the anode of the TV by using a high voltage probe. If you do not have high voltage then I would suspect the voltage doubler, the IHVT (Integrated High Voltage Transformer) or the Horizontal Output Transistor (I doubt this only because you don't have a power supply failure and I would expect this in a modern TV since the high voltage supply is tied to the low voltage supply), the more likely suspect is the voltage doubler. Second possibility I would check is the CRT socket board and CRT filament. Unplug the TV and with a multimeter set to read resistance check to see if the filament pins read a low resistance if so the filament is good. Plug the TV back in and turn it on and check the voltage on the CRT board and compare them to the schematic values. These two tests should localize the issue. Now, If you have a background in electronics, this should be no problem to do, however if you do not have a background in electronics, I would suggest that you have a qualified TV technician troubleshoot and repair this TV set.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 01, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
1993 46 inch Magnavox no picture
Hello All,
I posted this earlier, however I believe it applies in this case to:
This can be any number of things, here is a possible listing:
1) No High Voltage (check the IHVT or the trippler)
2) CRT filament transformer winding open (check the windings that supply voltage to the CRT filaments)
3) Video / CRT socket boards bad (highly unlikely but check anyway)
4) High Voltage power supply malfunctioning (related to problem #1)
This listing is a good starting point. I would suggest that you purchase a schematic to aid in testing the voltages mentioned in the 4 steps above. If you have a background in electronics then do the above, if not please ask a qualified TV technician to perform these steps.
Thank you,
I hope this helps,
Shuttle83
Nov 02, 2008 | Philips Magnavox 55P9271 55" Rear...
Panasonic television
This is not something that you can fix, the sound is the high voltage section with the horizontal output transformer. The reason is a possible flyback transformer failure or the high voltage diode is bad. Most electronic shops can fix it.
Nov 26, 2017 | Panasonic TX-28CK1 28" TV
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No pictureq
maybe you have defective heater line tru the CRT board! check the heater line if have a 4.5 volts or 4.8 volts! can you see the back of picture tube!?! they lights coming out at the neck of the tube! if no light! you have defective heater supply!
Oct 16, 2007 | Orion1934 19" TV
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
Tv has sound but no picture
Sounds like you have lost video somewhere in the video circuits. Possibly the picture tube could have gone bad or lost filiament voltage. You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as the high voltage. Stargazer
Jan 24, 2007 | RCA G36710 36" TV
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
