Question about LG Microwave
Burning wire smell
I only have had this microwave for about 6 months. Today after school my children heated up an after school snack in the microwave and I smelt something burning. I looked all around and could not find anything. I had the windows open so the smell went away. Around diner time I used th microwave to warm up somthing to go with diner and I once again started smelling the burning wire smell. This time I unpluged the microwave.
  • 706 Answers
Hello jvtmad1,
All of the previous comments are relatively good ideas but let me offer some additional advice,
First off, You need to determine if the burning smell is coming from the Microwave itself or from the receptacle that provides power to it. Most wall receptacles are rated for 15 amps and should easily handle your microwave ovens power requirements. A simple check might be to run a hair dryer on the same receptacle without the microwave plugged into it. They draw comparable power so that should eliminate the recptacle as the culpret, On the assumption that the burnt wire smell is coming from the microwave itself, then your best bet is to return it to the store for a repair or replacement. Unless you are properly trained on how to sservice that, you probably shouldn't attempt it. As stated in previous comments, it should still be under warranty. If you have a bad filament transformer, magnetron or the wiring between them, that is not something you want to fiddle with yourself.
In summary, eliminate the receptacle on the wall as being the problem first.
If you find tha your receptacle is the problem, then you may be able to remove or disable power to it by switching off teh appropriate circuit breaker or fuse.. then take off the face plate and check the integrity of the wires going to that receptacle and making sure they are tightly secured to the terminals of the receptacle. I would assume that if that were the problem, you would notice a burnt smell as soon as you took off the face plate. Hope some of thes ideas help you resolve your problem...
Regards,
Rick
Posted on Nov 22, 2008
    Problem Solver:
  • 19 Answers
It sounds like to me that the power cord is not supporting the wattage the microwave is putting out check the fuse box and see how many amps the breaker is if it is less than the microwave you will have to move it or get a lower watt microwave
Posted on Nov 21, 2008
  • 67 Answers
You should first check the electrical outlet for overload or slack connection .if u dont know how get an electrician. your microvave does not seem to have any problems since it continues to heat your food. to make further comformation about the elect. point plug something else that has similar power ratings as the microwave and check for the same burning smell . hope this would be of help
  • LG Master
  • 9,098 Answers
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
My microwave was smelling like electrical wire burning specially when I was heating liquids in it. Suddenly it completely went off... Is it fixable or I should change it?
If you smelled burning electrical wire, I would definitely replace the unit.
An attempt to repair would probably cost way more than a new microwave!
Nov 02, 2017 | In Microwave Ovens
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
My microwave is not heating and I smell wire
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkllkj
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmore Elite microwave oven... 69-65e05590-000637. We noticed that it would not heat food or liquids... played with the power level a bit and it started to heat again...then a day or two later we...
Is this oven still under warranty? If so, take advantage. If not, remove the power plug and the case. Short out, with a screwdriver, the large can-shaped capacitor with two terminals sticking out. Check the wiring and circuit board for signs of burning. If everything looks ok, remove the thin sheet metal wave guide that sits above or beside the microwave energy port into the cooking cavity. Under the sheet metal, there is a metal fan-like device called a 'stirrer' that has a plastic bearing. Remove this stirrer and smell the bearing. If it smells like the burning wire smell, replace the stirrer. You can buy it through 'Sears Parts' online.
Sep 14, 2009 | Microwave Ovens
MY SAMSUNG MW6574W OVEN FUSE BLOWS AFTER 4-5 MINS OF REHEATING-NO SMELL OF BURNING -EVERYTHING ELSE WORKS FINE- NO LOOSE WIRING-ALL BULBS WORK FINE TOO- THE FOOD HEATS UP FINE EXCEPT THAT THE FUSE BLO
the insulation of the wiring has detiorated and with temperatue rising it further deteriorates. thus increasing the current consumption and blowing the fuse
May 21, 2009 | Samsung MW6575G/MW6574W Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
LG Microwave Logo
1,317 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
