Microsoft Windows XP Home Edition Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound Device Problem
There is no sound device in computer one day it vanished from my computer so i would be glad if u could help me
Anonymous
Level 3:
Master:
Sergeant:
  • Master 461 Answers
  • Posted on Nov 20, 2008
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
461
Questions
0
Helped
110783
Points
1238
Not sure how could the sound device vanish from your PC may be you have accidentially delete the driver... If you could advice what type of sound device you are having i might be able to help.. mean time you may want to read below link which might find solution to your problem
http://etech.maiila.com
hope this helps
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
2answers
In my Destop system Audio Sound is not coming
Check the device manager for any conflicts with the drivers. There would be "Other drivers" listed if there was any drivers that were not installed correctly. If there is any listed try right clicking on them and selecting to reinstall drivers.
To get to the device manager:
Right click on my computer or Computer > select properties > then click on hardware tab on top then device manager or click on device manager link.
Computer Repair - Support
www.jdtechsource.com
No audio device
sounds like you need drivers installed for your sound card(if your computer has one, which most do now) ... what kind of computer do you have? Make and model? What Operating System(version of Windows) are you using also? I'll gladly help you find drivers.
I just replaced my power supply an after booting up my computer doesnt see any sound device at all, even though its been integrated into the mother board
My friend, I am glad you have identified your sound card. Remember, when dealing with a computer, it doesn't care what you know about it, the computer must know about it - where ever it is.
Please check your device manager to see if the sound device loaded properly and the driver is running. You will probably have to reload these drivers - get them from the manugacturer of the computer/mother board.
What ever happened was 97% not caused by the power supply replacement.
Thanks for your question at FixYa.com
No sound in windows XP. Device Mgr. says all devices are enabled and working." Audio and Sound" says 'No Device." I tried " Install new hardware," but it says all devices installed and enabled. Dell...
Need to know your laptop model?
Download drivers from dell or the manufacturer of the sound card/mainboard. As you install these the No device should vanish and it should start working. Also try windows update...custom install...optional updates .look for sound drivers like AC97 or realtek, if they are listed select them and try that.
No sound. had it two days ago
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
Hope this helps
2answers
Sound is not coming in my computer
go into the control panel and into the sound manager,(start,control panel, sound and other audio devices) then check all the volumes are up and not muted.
If that fails, go into device manager, expand the device tree and right click on the audio device, click properties and check the driver is installed, and if necessary update the driver or roll back the driver.
1helpful
Windows media player is not playing movies with sound
Need to install the sound driver from the motherboard driver CD.Once installed the sound device will work.Good luck and please do post comments if this does not work, will be glad to help out.Please do rate my solution.
Sound problem
I recently made formate to my PC when it got virus the DRIVER CD the mother board box in not responding for the audio drive
installation
1helpful
2answers
I NEED HELP
Please post the make / model number, and I will be glad to link you to the site to obtain the sound driver.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
