Question about JVC Cameras
JVC GR D247EK #140M0089 - Camera stopped loading cassettes. Remains in eject position.
  • 95 Answers
You must clean up your camera using your tape head cleaner.
The sign eject tape indicates that your tape head needs cleaning.
Posted on Nov 26, 2008
  • 71 Answers
Remove the battery for 30 minutes and try again. When putting the tape on camera press only where indicated by an arrow. Good luck!
Posted on Nov 21, 2008
My camera is reading an E3 code and eating my tapes
Could be your reel has a problem or capstan gear is broken. To confirm if gear is broken, apply power to your camera and eject the cassette housing(with or without cassette) and take a look at your idler gear(found at the center of supply and take up reel) if it is rotating. It must rotate momentarily and stop. Good Luck
Mar 09, 2010 | JVC GR-AXM17U Camcorder
I have a jvc gr-sxm26u camcorder and it has two problems... the tape door will not open when the eject button is pushed to the left. 2nd problem. the screen indicates that there is a problem labeled as "...
E01 Mechanism has not fully loaded up to the stop position
E-01, E-02, E-05, or E-06 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code which is to inform a technician which area of the camcorder to examine in order to ascertain the nature of the problem. Try the following steps:
1) Remove power source for 1 minute. 2) Reattach power source. 3) Try operating the camera.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E- 04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
A common E01 problem with the JVC is caused by electrically conductive residues on the very end of the connector strip which connects the small front circuit panel to the main circuit panel (this residue can only be seen under a microscope). Symptoms are, the mechanism remains closed or the cassette holder will not latch down and remains permanently raised. Basically the micro cannot read the mechanism position data. The connector strip needs to be taken out & carefully cleaned with alcohol.
If all else fails then its a trip to JVC service and a biil of between $`100 and $250 depending on what the problem is. My last E01 was a motor change and cost $180 but the cam has been fine ever since but next cam will be a Canon..
Oct 14, 2009 | JVC GR-SXM260U Camcorder
Jvc- gr-d740 camcorder's cassette is not ejecting message is showing that unit in safeguard mode please advise
There should be an error code star with E-01 to E-06.Below is an example you have to make sure that which error code showing on your camera
Whenever some abnormal signal is input to the syscon CPU,
an error number (E01, as an example) is displayed on the
LCD monitor or (in the electronic view finder).
In every error status, such the message as shown below
E01 LOADING--------
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Sep 25, 2009 | JVC Video Cameras
EO1 unit in safeguard mode
Try to replace loading motor
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the loading direction for 4 seconds
or more. This error is defined as [E01].
Jan 09, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
Jvc camcorder
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
Nov 02, 2008 | JVC GR-AXM17U Camcorder
JVC GR-DVM50
the only way you could remove it manually is by removing the covers and applying power to the capstan motor its alot of work.
Nov 17, 2007 | JVC GR-DVM50 Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Eo4 error
hi a malfunction of some kind has occurred in this case the camcorders functions become unusable. -eject the cassette once and re-insert it - it claers up yoy sould consult your nearst jvc dealer. good luck
Apr 07, 2006 | JVC GR-DX25 Mini DV Digital Camcorder
Cameras Logo
88 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
