Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture is dim and white is kinda blueish green tinted
I just got this tv. it was given as a gift and I believe moved a little rough. First day the picture was perfect. now the picture is dim and its not as clear as before. the whites do show a blueish green tint to them. I went into the setup by doing the display #5 volume up power sequence and tried to adjust accordingly without any luck. when I turn up the brightness the colors are not sharp.
  • 67 Answers
The crt socket is bad and needs changing
Posted on Nov 22, 2008
    Scholar:
  • 188 Answers
I have to agree with Shuttle83. All the symtoms point to a tired CRT. A little vibration would not cause the symptoms you listed. The problem may also be an issue of input power voltage to the TV but it's a stretch. Now how the picture looked so good when first fired up is interesting. Did you move the TV to a different AC outlet? Just wondering if the AC power source or plug connection is an issue. Last gasp trying to help you.
Posted on Nov 21, 2008
    Genius:
  • 1,139 Answers
Hello jeromek28,
This may be a CRT problem. From what it sounds like i.e. dim picture, colors not bright. If you have a background in electronics I would tell you to check the voltage levels on the CRT pins and compare them to the values on a schematic, however if you do not have a background in electronics, I would suggest you taking the TV to your local TV repair shop and have them troubleshoot your problem.
Here is a possible list of things that might be wrong:
1) CRT going bad (The shop can try CRT rejuvenation if needed)
2) High Voltage on the anode not at proper levels (The shop can check this with a HV probe)
3) Video output levels low (The shop can check the voltage and signal levels on the CRT socket board, and on the video amplifiers.
These are the three primary possible issues.
I hope this helps,
Thank you,
Shuttle83
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
How can I fix a synmaster b1630 monitor that has green tint on screen now?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 27, 2014 | Samsung SyncMaster Computers & Internet
Green tint to picture.
Are you using the componant connection on your tv? If so, check the red, blue and green cable connections on both ends. They carry your
picture info to the tv. The audio is carried by a red and white cable. There should be 5 cables for a componant connection. 2 reds, 1 white, 1 blue and 1 green. I hope I have guessed your problem correctly and this helps you.
Apr 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
91 tempo run rough with white exhaust
If you are sure it is white smoke and the car overheats or looses water,The head gasket is bad.
Or It's valve seals or rings smokes (but the smoke would have a blueish tint)
Jun 04, 2009 | 1991 Ford Tempo 4 Door
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Aug 07, 2007 | GE 27GT619 27" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
