Question about Kenwood Car Audio & Video
Hello, I have a Kenwood KDC-MP225 powering a KAC-8101D that was pushing 1 Bazooka EL1200, the last amp blew the other 1... I was driving along 1 day and cranked it up before the cd started playing, I don't ever do this! Well, the subs died out! I thought It finally killed the other speaker, hard to tell in this enclosure... I found out today when I hooked up a much smaller speaker to test the output it was putting out limited watts. It sounded like it was wired into the head unit. My LED is solid blue, I've tested the output transistors in place & all is well there. Anyone have any ideas? I really want to pull both banks out & test all the transistors but I assume the problem may lie elsewhere... Maybe the preamps from the head unit? Any help would greatly be appreciated!!! John
    Problem Solver:
  • 15 Answers
First off try a different source that you know works that you can control the volume of. (ipod) This will tell you if the amp works. If it still doesn't work try a different speaker that you know works, any speaker will do, just keep the volume down. Second see if running a new set of RCA's helps maybe something got pinched if it still is not working then your head unit line out is bad, try a different output and see.
Thanks,
Mark
Posted on Nov 21, 2008
I have kenwood kdc mp225 and cant figure out how to turn amp on through radio
there should be a blue/white stripe wire. run this wire to the remote turn on of the amp.
Oct 11, 2010 | Kenwood Sirius KDC-MP225 CD Player
Switches off when playing a cd. Fine on radio
sounds like you have the power antenna remote wire (blue) instead of the amp remote wire (blue/white stripe). when you go from radio to cd the power antenna wire shuts off.
Jun 11, 2010 | Kenwood KAC-8101D Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Kac-8101 no power
no its not dead u prob blew a couple of heat sensors or a capacitor. most defenetly a capacitor. ceck ur capacitor and see if its blowned
Jun 28, 2009 | Kenwood KAC-8101D Car Audio Amplifier
I would like to know if an mp3 play can be hooked into this unit
You need this adapter or one like it:
KECA-C1AUX
Search Kenwood aux adapter on eBay or Goggle
heres tha manual to download:
http://inform3.kenwoodusa.com/manuals/KDC-MP225.pdf
May 30, 2009 | Kenwood Sirius KDC-MP225 CD Player
Low output from amp
From a former DJ, make sure that the speaker circuit is matching the load that is required by what ever amp that you are using. If the amp is rated at 1000watts/ channel into 8 ohm's then your equivalent speaker circuit has to match. I repeat has to match! If it does not the amp will either short out or be overloaded. If you are using all 8 ohm speakers on a amp that rate its output at 1000 watt/8ohms then you you have to match the watts and the ohms. Depending on how much power your speakers take you may have to use more than one speaker to handle the power. If you have to use more than one speaker you will have to use a series/parallel circuit to keep the ohms at 8ohm. You have to use ohms law for adding resistor in series and paralell. If more is needed please reply.
Nov 20, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Amp on but no bass
1st make sure the speakers are not bad, check th eimpedance with a multimeter, the voice ciols should read 3.9 to 4.3 ohm's. if any of your subs are below this most likly the subs are bad. if they are ok make sure the ground for the amp is good. now the last thing is the amp. try another pair of speakers, even if it's smaller ones, just make sure they are 4 ohm speakers, keep the vol. very low during your test. if the other speakers do not work then have your amp serviced or replaced. good luck
Dec 19, 2006 | Kenwood KAC-8101D Car Audio Amplifier
KENWOOD KDC-MP225
I THINK THE ILLUMINATION WIRE (ORANGE)AND THE IGNITION WIRE (RED) ARE CONNECTED TOGETHER. THE SOLUTION IS DISCONNET THE ORANGE WIRE YOU NOT REALLY NEED IT.
Dec 17, 2006 | Kenwood Sirius KDC-MP225 CD Player
Car Audio & Video Logo
70 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
