Question about LG DLG5932W Gas Dryer
LG Dryer DLG7188RM LP conversion back to NG
Hello there
as you have answered before, I have a gas dryer and it had been converted to LP. I need to go back to NG and I know I need this part...4948EL4001B
I can get this online or at a dealer near me, however, how do I take the unit apart? How does the pressure regulation occur? Thanks
PS model number is gld7188rm not dlg5932
  • eyekutr Nov 20, 2008
    Thanks so much, time to go find the part. Why does the LP conversion look like it is more than one piece in a kit?? there are no other parts to retrofit for NG? Thanks again greatly
  • eyekutr Dec 04, 2008
    WHen we went to test the conversion back to NG, we had not assembled the entire thing back and it would fire up and almost within a couple seconds shut off. We figured it needed the closed loop within for proper operation. Once we reassembled the front on, and retested, the burner came on and stayed on as it should. Thanks
  • 1,543 Answers
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Posted on Nov 20, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 20, 2008
    Other than the orifice and the short instruction sheet, there is usually a sticker to put on the dryer so that service personel will know that the dryer has been converted to LP.
    Only the Natural gas orifice is needed (parts wise) to convert back to Nat gas.
Admiral dryer
Who did the conversion to lp? Do you have the old part from the conversion still? If not you can order a kit to put it back to stock which is ng. Not hard for a guy that's handy but time consuming. 2-2.5hrs.
Feb 08, 2014 | LG DLG7188 Gas Dryer
I am looking to convert my kenmore 970-c92062 ng dryer to lp.
The supplier of the LP gas can supply the needed parts for conversion.
Aug 09, 2017 | Amana Dryers
How do I convert a gas dryer model # (DLG2302R) to LP ? Does the required Installation kit come with the unit upon delivery
Here is a link to the conversion kit you will need. It comes with the instructions you will need to do the conversion to LP gas.
Dec 01, 2010 | LG Dryers
My lg dlg7188rm gas dryer will not heat. the gas
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Feb 01, 2010 | LG DLG7188 Gas Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Ng to lp gas conversion how do I do this?
The basic difference is gas pressure , which means changing gas jets. You had better call a service man.
Apr 25, 2009 | Dryers
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Removing engine
I need to get the back off of my LG gas dryer. I need to convert it to LP. I have the conversion kit, but can't get the back off the dryer.
Nov 05, 2008 | Kenmore 65924 Electric Dryer
LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Jan 25, 2008 | LG DLE0332 Gas Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
LG DLG5932W Gas Dryer Logo
818 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
