HITACHI 50ux10b rear projection TVfrom about 1993
HITACHI 50ux10b rear projection TV from about 1993
The TV would cut the pic and sound periodically and then come back on after a few minutes --all for a few days --
And now , it wont come back on at all--The red light comes on indicating power but there is no pic or sound --I tried re-starting several times and even pulled the power plug and still nothing, except the red light --I even checked all the cable lines and other connections--
Could this involve extensive repairs ? Sure would appreciate your help.
Thanks,,,,Ralph -- repko@cox.net
    Scholar:
  • 93 Answers
Sorry,time to move on and buy a new TV.Too costly to repair!
solutiondoct
Posted on Nov 22, 2008
    Sergeant:
    Champion:
  • 346 Answers
You might have to change the power regulator. you need a qualified tv technician to solve this problem
Posted on Nov 21, 2008
  • 125 Answers
I fix one like this one; it was about 300.00 there was problems with the power supply,some capacitors leaking and the regulator ic was bad. only a technician could do this job
    Genius:
  • 2,920 Answers
It will run you about 400 to repair
    Genius:
  • 1,139 Answers
Hello repko,
This looks like a problem related to your High Voltage Protection circuit. This circuit shuts the TV down when it senses a high current condition (a short in a vital circuit). It may not involve extensive repairs, but it will involve some repair work. I can give you a better diagnosis if you do a few things for me.
1) unplug the TV and take the lower rear panel off
2) look at the back of the panel or in the TV for a chart showing you the diagnostic LEDs
3) Look at see if LED D912 is red or not (this may differ in your model, if so write down the numbers of all the diagnostic LEDs and there condition on or off red or green.
4)post these in a reply to this topic.
Once this is done I'll be able to give you some idea of how extensive this may be.
Thank you,
I hope this helps,
Shuttle83
Phillips tv stand by button stuck no sound r pic mod.no.42pfl9632d/10
the model is phillips and picture above is Hitachi--the philips is not customer repairable--call around and get a estimate.
Oct 17, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi rear projection tv 50ux10b Picture and sound would periodically go off and then come in the past few days ---Now , the Red light comes on indicating that there is power , but no more sound or...
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Jun 02, 2017 | Hitachi 50UX26B/27K 50" Rear Projection...
Pic bad
Repair the hyper module.... See some of the previous posts for this problem...
Bill
Oct 28, 2008 | Toshiba 42H81 42" Rear Projection...
HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Oct 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50UX10B rear projection TV
Good Day, eledttech;
Symptom: NO SYNC ON MAIN PICTURE PIP OK
Cause: IX04.
Good Luck, big IRISH.
Aug 18, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Projection tv no picture has sound no picture
Try resoldering the vertical output IC. The crts may be blanking due to vertical deflection dropping out.
Apr 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
Projection TV problem
sounds like the vertical deflection is causing the CRTs to blank cause you still have sound and on screen displays. Try resoldering the vertical output IC see if that helps. If not you may need a new vertical output IC. Let me know if i can assist you further.
Apr 04, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Apr 08, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
