Canon Pixma MX310 Office printer. continues to jam paper. in the maintenance panel i cannot perform an alignment check or deepclean. Attempt to copy feeds a whole sheet thru and chokes on the 2nd piece. I may have a warranty on it , just trying to fix it for a friend. Cartridges are new. restored to factory settings. no luck.. any help out there.. or just toss the machine in a pit that's on fire.
    Problem Solver:
  • 5 Answers
As i was posting here. I instructed my elder friend to perform the 'Clean Print Roller' routine from the user manual. After 3 times he said it started to work. Thnks for your inputs.
Posted on Nov 25, 2008
    Scholar:
  • 130 Answers
Printers that jam usually have worn feed rollers, some where in the machine, or a bad sensor. If worn feed rollers are the problem the paper usually jams in different locations in the machine. If a sensor is bad the paper usually jams in the same spot each time paper is fed into the machine. A new machine does not have worn rollers, but could have a broken sensor. It sounds like the a roller might be worn. There is a company called Tech Support that use to sell a cleaning fluid for paper feed rollers. You can use alcohol but alcohol dries out rubber, but you can use it to diagnose the problem. Clean all visible rollers. Especially the rollers that the paper jams between.
Posted on Nov 20, 2008
Printer displays alarm and indicates there is a paper jam. However, there is no paper jammed. What can be the problem?
Could be dirt blocking a sensor, damaged sensor, or paper pieces where the sensor can pick them up.
Mar 03, 2016 | Canon Pixma Mx310 Office All-in-one...
Why does my Canon printer MX310 show paper jam when there is no paper jammed?
Hi
try switching printer off & on. If that doesn't work, check the paper path for stray bits of paper or another obstruction.
Sep 20, 2014 | Canon PIXMA MX310 All-In-One Printer
How to open the paper path of a canon MX371 to remove paper jammed
Description:
A paper jam has occurred during printing.
Resolution:
1.Locate and remove the jammed paper from the printer.
2.Press the [Resume/Cancel] button on the device to continue printing.
Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
Jun 03, 2014 | Canon PIXMA MX310 All-In-One Printer
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Blurry printing
Brain Supplements are the best way to get your brain sharp and healthy. It also helps to increase your brain memory.
Jul 20, 2017 | Canon PIXMA MX310 All-In-One Printer
Canon mx310-cant even figure out how to copy!
Canon PIXMA MX310 Office All-In-One Printer User Manual
here you go here is the manual for your printer hope it helps and thank you for using fixa
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
234 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
