Royal Jet Flow Gravity Furnace (OLD)
My girlfreinds house is old and the furnace is a Royal Jet Flow FG-2-55 Gravity Vented natural gas fired furnace.
I cleaned the thermal coupler and flame sensor and the furnace now burns longer and works great! Except, now when it starts the gas flows for about 1 to 2 seconds before it ignites. This causes a good flash and about a 6-inch flame flashs out of the venting. Needless to say this is not good.
did I do something wrong, or do I need to adjust the pilot flame making it larger or do I need to replace something? I tried cleaning the burner but it only worked for about two firings then it started and got worse (3 or 4 seconds) before it ignited BOOM!
  • kcnodlr1 Nov 26, 2008
    Merle, I have the same problem and am also looking for solutions. I have been told that its, "the nature of the beast". I have purchased a new honeywell pilot assy., $80.00 bucks, and I am going to install it today. I will keep you advised as to the outcome. kcnodlr.
3 Suggested Answers
  • 17 Answers
SOURCE: Gas flows to long before igniting.
try cleaning the crossovers between the burners. Also look closely at the flame and make sure that the burner is firing all the way to the pilot. Sometimes its just a few little holes that vent a little gas to give the flame a path to follow will be stopped up and cause the condition you describe
Posted on Nov 18, 2008
boysor2933
  • 293 Answers
SOURCE: Replaced pilot sensor. Still not lighting furnace. Have a high humming sound for about 2 mins then nothing. Any suggestions? Furnace is about 8 years old
The humming sound might be a stuck blower motor or a motor that won't start due to defective starting capacitor.
Posted on Nov 06, 2012
Where can I find a manual for a Royal Jet Jr, model EG2-50 Gravity furnace.
I am looking for that exact wall furnace to replace one that is not working well. In fact I need two of those EG2-50 Junior Jet
Jan 22, 2016 | Heating & Cooling
Tip
Renting and Paying the Gas Bill
This past week I changed out an old hot air furnace in a rental unit that made me question why the tenant did not go to the owner and offer to pay more rent in exchange for getting the furnace changed out sooner. If you are a renter that is paying the gas bill, then you need to think about this.
The hot air furnace was at least 60 years old. It had been coal fired furnace that was converted to gas many decades ago. The pilot light of this beast was more of a torch than a pilot light. When the thermostat called for heat the flame roared for 15 minutes before the exterior blower unit that was added when the furnace was converted to gas, started up to move air through the furnace and into the house.
As I was starting up the new unit, which took up less than 1/3 of the space of the old beast, the renter came and sat down on the basement steps looking on in amazement. How would that little thing make enough heat for the house? A few minutes later those questions were put to rest very quickly.
After starting the new furnace and burning off the oil that always smokes up the house a bit on a new startup the new little unit had the house warm as toast and was shutting down. Wow, that took less time than the old beast took to just warm up!
The renter related to me how that the old furnace cost over one hundred dollars a month just to run the pilot over the summer months. The wintertime heating bills were many times higher than that. The difference between the bills of the old unit and the bills that will be coming now will be unbelievable. A savings of 40-50% is not at all out of the question.
Now, if you are renting and are paying the bill to feed an old monster of a heating system, I suggest that you make a proposal to your landlord. Offer to pay a bit more rent in exchange for a new heating system. Not only will you decrease your gas bills enough to pay some extra rent and still come out ahead, but you will have the peace of mind that you have a safer heating system under the roof that you also live under.
on Dec 07, 2009 | Heating & Cooling
Empire furnace Model # GWT-35-2 seriel # 0614425864. I had a furnance repairman replace the to snap switch. Still have the same problem at times. Furnace will not start unless snap swich is pressed.
As an Empire Comfort Systems dealer, I'm not quite sure what your mean by "snap switch"?
It certainly isn't anything that's listed in the parts manual for your gravity vented furnace.
Your furnace is equipped with a manual "reset vent safety switch."
The manual reset vent safety switch will cause gas flow to the main
burner to "shut off" due to improper venting or a blocked flue.
Is this what your serviceman replaced? Since then have you or anyone checked to see is vent pipe is clogged or is improperly venting?
If the manual reset vent safety switch continues to "shut off" the gas
flow to the main burner. A qualified service person must be contacted
to inspect for improper venting, blockage in the vent pipe or the
manual reset vent safety switch for being defective.
Hope this helped to head you in right direction.
Feb 10, 2011 | Heating & Cooling
What do I need to do to covert from propane to natural gas on 100,000 BTU furnace ? It is a weather king md.80PJ10ECR01
Take your Model and serial number to an HVAC parts house and they will get a kit for you that switches over from propane to natural gas. The spring in the valve is different and the orifices are different. Propane runs about 10 to, 11 inches of water where natural gas is about 2.5 to three. So if you did not change the springs and orifices you will cause the furnace to over heat and posibly catch on fire. These kits are easy to change the orifices just unscrew. The top of the gas valve has cover over the spring and an ajustment screw inside just remove that and pull out old spring and insert new one. Be careful with the springs they are very tiny and not much thicker than human hair. You really need to get someone to set the pressure for you. Feedback welcome Rus
Dec 07, 2009 | Weather King Heating & Cooling
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
We have a old house and the gas hot water heater and the central heating unit is vented out an old chimney and the heater is building up condinsation, how do i vent the heating unit out the wall, unstead...
actually if you vent your furnace by code, it would probably be cheaper to have a chimney liner installed up the old masonry chimney. you may be able to buy a kit and do this yourself. any time a new furnace with a draft inducer on it is installed, it must be vented into the proper flu material. if it was vented into your chimney, it may not have be installed by code for your area. you may talk to the instaled if they are still available and maybe that can return and do it correctly. if you leave this vented into your masonry chimney, the acid content of the exhaust will ruin the chimney. a liner will also get rid of the water problem you have.
Jan 26, 2009 | Heating & Cooling
Nov 18, 2008 | Williams 2509612 Ceramic Mid-Size Heater
My Honeywell gas furnace won't fire up. The pilot is working , the fan will turn on if set to manual, but won't fire. I live in Canada and am freezing. thanks.
is this a power vented system if so check the ventr motor . it must run first alowing the gravity swtch to make and send 24v to the gas valve- if its not a vented unit sounds likely you have a main valy or posibly a mercury or thermo couple problem. hope this helps.
Oct 07, 2008 | Heating & Cooling
Heating & Cooling Logo
1,106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
