Question about Kicker Solo-Baric L7 12'' Car Speaker
Kicker l7 I have a tear in my l7 around the out side of the rubber edge how can i fix it?
  • Anonymous Mar 17, 2014
    I have a set of older MTX Thunders 10" and 15" that the foam around the outer edge has come off. The speakers are older but with very little use. I was wondering if there is a fix or if there is somewhere I can send them to have them repaired. The set of 8" Blue thunders I have have rubber around the outer edge instead of foam. Any ideas?
Blown voice coels
Posted on Jan 03, 2007
    President:
  • 3,130 Answers
That is called a suround my freind. depending on the exact size of the foam surround they are available with good instructions at many many places that do speaker repairs on-line. Heres one I have used in the past http://www.simplyspeakers.com/2doityourself.htm?src=overture Like I said there are tons of them available on-line. Simply search for speaker surround repair. Good Luck Please do not forget to rate this thread.
Posted on Dec 15, 2006
SOURCE:
Need help fixing my suwoofer kicker L5
I have 6-10's and 4-12 L7's in around the same condition with the solo "S" blown out of the cones, its amazing what 20kw does to them in the right box..lol.
you could try sanding around the hole than c.a. (black rubber toughened super glue) a patch of thin cotton fabric, tack down the edge with glue, than saturate the cotton with glue and spray with accellerator, it should last quite a while before it flies apart.
Apr 07, 2014 | Car Audio & Video
My 12 L7 the rubber came off the cone and doesnt hit as hard what kind of glue would fix my problem
Hi, Jr.
I'm sorry, but glue will not fix this problem. When the rubber or foam edge of a speaker breaks down or deteriorates because of age, it becomes almost like dust, which is why it cracks and then breaks apart and falls away from the speaker. The only way to fix it (besides replacing the speaker) is to replace the edge, or "surround". At this link, http://www.simplyspeakers.com/All-Foam-Kits_c_118-1-3.html, you will find a kit that you can buy to repair your speaker for about $30. The standard 12" repair kit will work if you have an 'angle cone edge attach' type speaker (see the bottom of the page for a picture of what this means). This page, http://www.simplyspeakers.com/speaker-repair-foam-edge-replacement-instructions.html, will show you step by step how to use the kit to repair your speaker.
Good luck, and please remember to rate my help.
Thank you for the opportunity to help you.
Oct 14, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a kicker 15 inch L7 solo baric and the rubber piece around the plastic part of the center of the sub has come apart from the outside black ring. how can i fix this?
You can purchase a silicone sealant set, specifically for speakers. Its quite easy to use. Ebay has alot of them and they are relatively cheap.
May 03, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 1 "12" kicker L7 and i got into a car accident. the sub works greath but the outer face has a crack in it.. its not big but i wanted to know what could i do to fix the problem
If the cone has a crack in it, that is USUALLY fatal, but you MIGHT try using the BLACK ABS plumbing glue to repair the plastic.
I don't know what you mean by the front face.
IF you mean the frame around the cone, I would grind out a groove (Vee it) over the crack and mix and fill with JB Weld. Paint to match when the material has set up and is smoothed a bit.
Nov 09, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How do i rebuild a set of solobaric l7 subs 15s
you have to remove the rubber surround holding the front of the subwoofer to the metal frame.the voice coil is a coil of copper wire.you should be able to get it through kicker.its not the easiest thing to do i recomm seeing if kicker can rebuild it for you or try a local speaker repair shop theres not alot of them but you can find them.first get the rebuild kit if your going to do it.it should show you everything you need to do. if you need more help let me know bertman285@hotmail.com
Oct 08, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
My solo baric L7 needs a new rubber lip
Hello saladinmali,
I'm sorry to hear that your sub was vandalized.
I'd start directly with Kicker and ask if they sell a replacement "surround" for the sub. If so, they will also have removal and installation instructions. Email them at: support@kicker.com. Or call (405) 624-8510. A user installed surround would be the least expensive and should run no more than $40-50. If Kicker does not sell a repair kit and requires that you return the sub to them for repair, expect to pay shipping both ways, as well as for the repair itself. My estimate would be about $125-150 total.
Hope this helps.
Jul 01, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My spider in my l7 kicker is riped how do i fix it
ya i fixed it mi self i ant payin for this **** it retarded
Jun 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Cracked Rubber
what i would do is:
super glue the cracks, allow to dry and then use a silicone lubricant spray and let sit for about 10 min then wipe clean. silicone spray can slightly restore the rubber/foam
Mar 16, 2009 | Car Audio & Video
Kicker L7 plastic faceplates
You will have to buy the whole cone replacment kit for that part or get from bad speaker. Both can be purchased on ebay or other sites.
Feb 02, 2009 | Q-Logic QLT-.3508SS Car Subwoofer
Solo baric l7 WOOFER... CAN I REPLACE THE VOICE COILS?
well you can bring it into the place you bought it.. or a place where they sell kicker brand subs.. and ask them for a fix..
they'll either order you another one or.. they'll send it to be fixed.. depends on what it is(note) kicker L7 is made to be taken apart and fixed
Jul 06, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
271 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
