Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Hitachi rear projection tv 50ux10b Picture and sound would periodically go off and then come in the past few days ---Now , the Red light comes on indicating that there is power , but no more sound or picture . I tried restarting several times and even pulled out the power plug and then tried again ---several times-- If this very complicated to fix -- like does it need a new tube? --It said free or did miss it ? Thanks ,,,,,Ralph
    Top Expert:
  • Hitachi Master
  • 75,767 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on Jun 02, 2017
ctf1800
  • 4402 Answers
SOURCE: HITACHI 52"PROJECTION TV WITH BAD
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
  • 927 Answers
SOURCE: Hitachi 50UX10B rear projection TV
Good Day, eledttech;
Symptom: NO SYNC ON MAIN PICTURE PIP OK
Cause: IX04.
Good Luck, big IRISH.
Posted on Aug 19, 2008
  • 38 Answers
SOURCE: HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
Posted on Oct 13, 2008
mistersony
  • 320 Answers
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
tlm931
  • 273 Answers
SOURCE: TV PIcture and Sound Shut Down
it would appear its shutting down in a protect mode
its possible its a convergence circuit problem or something on the deflection bd
but it most likley will require some assistance from a tech that is used to working on this type of set
if you noticed when it does come on that the colors are all off line then suspect convergence circuit trouble the the green leds tell you what source is still alive there is a chart in the cabinet that will correspond with each source voltage that can lead you to tracking it down if you know what to look for and have the tools to do so
Posted on Jan 21, 2009
The red light on front of tv is on but tv itself (picture), sound
Check all the picture bulbs works.
This is a plasma tv right?
U have it along time right?
Aug 13, 2009 | Hitachi 43FDX20B 43" Rear Projection...
HITACHI 50ux10b rear projection TVfrom about 1993
Hello repko,
This looks like a problem related to your High Voltage Protection circuit. This circuit shuts the TV down when it senses a high current condition (a short in a vital circuit). It may not involve extensive repairs, but it will involve some repair work. I can give you a better diagnosis if you do a few things for me.
1) unplug the TV and take the lower rear panel off
2) look at the back of the panel or in the TV for a chart showing you the diagnostic LEDs
3) Look at see if LED D912 is red or not (this may differ in your model, if so write down the numbers of all the diagnostic LEDs and there condition on or off red or green.
4)post these in a reply to this topic.
Once this is done I'll be able to give you some idea of how extensive this may be.
Thank you,
I hope this helps,
Shuttle83
Nov 20, 2008 | Televison & Video
Oct 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Cause: IX04.
Aug 18, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Ultravision front projection
Good Day scooter351;
IT IS time to call an Authorized Service Center and have them come out and give you a written estimate, before they proceed with the repairs.
Good Shopping, big IRISH.
Jul 10, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No Picture on screen
THIS PROBLEM HAS HAPPEN TO ME WHEN MY LAMP WAS
ABOUT TO DIE. WHAT I DID WAS UNPLUG THE TV SET FOR
A SHORT WHILE, THEN WHEN PLUGGED AGAIN IT CAME ON BUT THE PICTURE WAS DIM AND THE LAMP ONLY
LAST FOR FEW DAYS AFTERWARDS.
W.J.M.
Jun 23, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Mar 02, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 57TWX20B powers on ( but no picture or sound)
f you had multiple power outages, i would contact the power company or/and insurance company and it should be covered under that, but sounds like power supply problem if you had power surges
if lighting cause it then it could be anything.
Feb 08, 2008 | Hitachi 57TWX20B 57" Rear Projection...
Open Questions:
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
