Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washer dryer jet system does not work
Zannusi Jet System ZWD 1471 W, the jet system no longer sprays water onto the wash load, the draw for the conditioner has often clogged and does not always take the conditioner, resulting in a dirty tray
  • Anonymous Dec 06, 2008
    3 months old , jets died
  • markw_freema Jan 03, 2009
    the tube was blocked, we managed to find that by probing the tube at the door seal end, admitted the bend made it dificult, so if it persists and we cannot reach the blockage from the door with a flexi probe then looks like strip down and probe from pump end,, yep, guk did come out.. many thanks
    Happy new year
    Scholar:
  • 86 Answers
Hi, this problem is caused by the recirculation pump which has either gone faulty or has been clogged up by to much washing powder/liquid! you will need to strip the machine top off first then the rear and the pump is located at the rear of the machine (depending on model ) it is easy to spot as it is the only one that has the hose attached to the pump which leads to the door seal. take it off check for blockages in the pump and pipe and hose if no blockage then replace pump. It will then work like new.........!
Good luck...................
Posted on Jan 02, 2009
Jet stsem water hase stopd comming in the washer
If you mean there is no water in jet system than I suggest to check circulation hose (dirty) of jet system and circulation pump otherwise problem is in " intake water".
Dado
Jun 14, 2015 | Zanussi Washing Machines
I have a Zanussi Washer/Dryer Model ZWD 1270W. When I set the machine to wash (any cycle), it fills with water, the water jet starts, it takes the soap powder then it immediately skips to the 'drain'...
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwd_1270_w_zwd_1270_s_zwd_1470_w.html
If you go to this website, they have manuals and you can ask questions also.
Just one thought. Have you unplugged the washer for a few seconds then plugged it back in? It's possible the "brain" needs to be reset.
Nov 02, 2013 | Zanussi Washing Machines
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanuassi jet system frony loader has a bad smell
hi this is joyce
They sell a product called affresh it cost about $10.00 you put in the machine and run a cycle and this should take care of the smell. if this does not do it then run pure bleach in despenser and run cycle no clothes in washer. this will kill the mold. also never close the door completly on the machine because this holds moisture inside the machine, so leave a crack in door so the machine will dry out some. this should take care of the problem.
thanks
joyce
Feb 05, 2009 | Zanussi ZWF1430W Front Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Zanussi Jetsystem
scrub above the soap tray to make sure the holes are clear if they are you may have a system where the fab condit water valve is u/s.
May 18, 2007 | Zanussi IZ161S Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
358 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
