Question about Amana Kitchen Ranges
Had the oven set to 350 it worked, went to turn it off the button would not work, so I hit other buttons and accidentally hit clean, now where the time normally is it says -F1- and is beeping and nothing is working to stop the beeping. it's an amana oven and the model number is ards800ww
  • 4 Answers
Over on the applianceguru.com forum someone posted this problem and the gurus there said it's the control board. You can order the part online and replace it yourself, it's probably around $150-$200 depending on where you get it. You may find a better deal on ebay too.
Posted on Nov 28, 2008
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven electronic oven control will not adjust, up and down arrow pads not work - stuck at 350. Is not locked out.
That sounds like a keypad problem. Try this: See if the control responds to each button ... press the button, hear a beep, hit cancel. Check if UP/DOWN work in any of the clock setting modes. If a specific group of buttons always do not register, it is likely to be the keypad. Sometimes the keypad connection gets oxidized and causes somes keys to go dead. We put a procedure to clean this connection on our website, link below. You have to open up the oven to do this, so you may want to hire a tech for this.
http://fixyourboard.com/techzone.html
- see under "ovens" section
Oct 12, 2009 | Whirlpool Gold GW399LXU Gas Range
I accidentally hit the time bake button instead of the clock button now my oven will not work. This is a Fridgidire oven model FEF372AS1. How can I cancell the time bake function. I have turned off the...
Are you getting any codes? Sounds like one of your touchpad buttons is stuck. CAUTION: Turn power off to oven at circuit breaker.  I would take the control panel off disconnect the ribbon from the touchpad and take a pencil eraser and clean the contacts. Reconnect ribbon connector back together. If this does not help write back..
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I accidentally turned on the wireless 5000 mouse magnifier and can't get rid of the magnifier. How do I turn it off?
Normal 0 The button on the left side of the mouse when pressed turns the Magnifier on/off. Just press it again and it should turn off.
I kept turning it on accidentally so I went in the control panel and switched the Magnifier to the right side. I added that below so you can set your mouse buttons.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Feb 17, 2009 | Microsoft Wireless Laser Desktop 4000...
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
106 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
