1997 Pontiac Sunfire Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spark plug have 97 sunfire with a 2.2 in it but put in motor from a 96 2.2 was wondering if the gapping inthe plugs is different also haveuing probs with the cooling fan when put new motor in it worked for while then engine light came on hasnet worked since , noticed the realy switch was backwards bought new one replaced fan temp gage sensor still nothing will come on if you unplug the gauge sensor but shuts off when you plug it back , any ideas.
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Dec 19, 2008
Anonymous
Expert
Level 2:
Answers
56
Questions
Helped
16415
Points
109
It may be a problem with either the computer or the temp gauge is rated to low or high
Spark plug gap for 2002 polaris personal water craft
Really need a Model as well are year and make, but this should help. You can also Google
make model manual
most are online, some Service manuals as well.
Thread: what is the gap on my spark plug - Greenhulk
http://greenhulk.net > ... > Polaris PWC Performance
May 22, 2013 · 3 posts · 2 authors
polaris 03 freedom 2 cyl. 720cc what is my gap supposed to be set at? I just got a new set of spark plugs for my pwc and need to know the ...
spark plug gap on a 97 sl 900?
Jun. 20, 2011
2002 Virgage 800 DI
Mar. 5, 2018
correct spark plug for a 2002 virage tx
Jun. 13, 2016
spark plug gap
Sep. 27, 2011
More results from greenhulk.net
Spark PLUG GAP - Page 2 - PWCToday
http://www.pwctoday.com > ... > Sea-Doo
Jul. 30, 2007 - curious to know... Do people typically re-gap their new plugs right out of the box, before installing them?
Thread: Spark Plugs - Polaris
Dec. 1, 2006
Thread: Slx Spark plug gap - Polaris
Dec. 12, 2006
Thread: SL 900 Spark Plug Gap - Polaris
Jul. 11, 2009
Thread: 650 spark plug gap
Feb. 3, 2007
More results from www.pwctoday.com
Need gap spacing for spark plugs. Wondering about the location of the fuel filter
Hello: There should be a white placard under the hood giving you the spark plug gap, Its called an ession label for your engine, the gap probably is .060 of an inch. The fuel filter should be behind the fuel tank or to the passenger side under the rear of the car.
2helpful
2answers
Cylinder 6 misfire
could be a couple of things. 1) bad plug or spark gap. check plug for burning on electrode. check gap. if you replace 1 then replace them all. 2) check wires for any white lines. mainly around the boots, but check it all. the white lines are tell tale signs of arcing. replace if needed. 3) chech distributor cap & rotor for arcing. if you have a coil pack it could be whatever pack is controlling #6
MY 96 PONTIAC SUNFIRE 2.2LITER WONT START AFTER IT RAINS OR IT WILL STALL OUT AFTER BEING TAKEN THROUGH AUTOMATIC CARWASH ANY SUGGESTIONS ANYONE?? THANKS!
check spark plug wires and coils for moistore put some lube on the coil wires check for spark after it wont start if itll crank but not start its 1 of 2 thinks no spark or no fuel usally when the coils get too wet they wont allow spark to come through or will cause it to arc
7helpful
2answers
What do you gap a spark plug at for a 1998 pontiac sunfire
Hello ryanjnichols: My name is Roger and I can help. You did not say which engine is in your car. So here are the plug gap for the two engines listed. The plug gap for a 2.2 engine is .040 inch. And for the 2.4 engine the gap is .060 inch. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
3helpful
2answers
No fire 96 pontiac sunfire
96 sunfire - press horn and you hear the relay neer the glove box but there is no horn noise. I can't even locate the horn. Any suggestions?
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
