Question about Hotpoint Dryers
Dont know what the fault codes are for my Hptpoint Dryer CTD80
I have a Hotpoint Condenser Ultima dryer, I never got an instruction book with it as it was 2nd hand, It keeps stopping and coming up with the fault F-10.
Can you please help me A7 tell me what iit is.
Thanks
Danielle from Australia
Try the Hotpoint web site for a list of codes - see http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Looks like this one is
  • F10 - Common of heater open or one shot open - Book a service engineer.
  • Posted on Dec 01, 2008
    • Hotpoint Master
    • 3,463 Answers
    Hi.
    F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
    Also make sure that you clean the filters regularly
    This should solve your problem.
    Posted on Nov 20, 2008
    Hotpoint ultima tumble dryer
    sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
    Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
    By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
    F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
    Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
    Condenser not drying stuff properly
    I am hoping your talking about a clothes dryer here. based on the model number you posted here. Does your dryer even feel warm to the touch as in any signs of internal heating? If not then here are some things to check. 1 the basics: Check the circuit breaker and make sure that both of them are in the on positon. Just trip them off and then back on again to reset them. 2. Check the power cord for any signs of a bad connection. It will show up as a dark discoloration. 3. I know you said you checked the lint filter but have you gone outside and verified that the external outlet vent is free of obstructions? If not please check it and clear any obstructions. 4. The heating element itself may be open. Ovetr time they are like light bulbs and the burn out requiring repl;acement. 5. There can be a thermostat failure causing an open circuit and no power to the heating element. 6. The motor switch also controls the heating element circuit and it is actuated when the motor is running. If the switch has failed it will prevent the heating element from being energized. 7. The least likely suspects are the timer and heat setting controls yet either of them can cause a no heat condition. You did not mention if it was a gas or electric dryer and the comments above are for an electric dryer. If you have a gas dryer then you can have 8. a bad ignitor, 9. a bad gas valve, 10. a failed gas regulator. Based on this model number CTD80 it does not cross to anything that I can find. The bottom line is your unit is probably worth the cost of getting it repaired. You may want to check your model number again please and repost it you need more information. It appears this is a UK model. I hope this was helpful. It certainly was educational here.
    Jan 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
    Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
    Error code 14 indicates dryer element fault.
    Checkelement-connections-and control module.
    Please leave feedback.
    Thanks.
    Nov 15, 2009 | Hotpoint Dryers
    Hotpoint ultima condenser dryer TC71 is running cold
    Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
    Apr 06, 2009 | Dryers
    Hotpoint Ultima Condenser Dryer - where is the reservoir?
    under the door, you need to take the small panel off and its there.
    Mar 03, 2009 | Hotpoint Dryers
    E30 error code
    Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
    Thanks for using Fixya.
    Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
    I have a hotpoint ultima 7kg condenser dryer which is leaking from underneath and not drying
    Check your user manual for faults to be found at the rear of the manual.
    If you don't have a manual go to www.hotpoint .co.uk.
    Click on After sales, then on download user manual.follow instructions.
    Good luck.
    Nov 30, 2008 | Dryers
    Washing machines
    hiya
    i take it this is a washer dryer, as the fault code f-14 is the dryer heater.
    hope this helps
    please dont forget to rate the helpfulness of this reply, thanks kj
    Jul 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Ultima Condensor Dryer
    on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
    Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
    Dryers Logo
    379 people viewed this question
    Top Hotpoint Dryers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
