Question about Konica Minolta Maxxum 70 QD with 28-100 lens 35mm Film Camera
Err message on display.
Minolta maxxum 70 35mm. Camera will turn on and take a picture but the second the shutter closes... an ERR message comes on the display and the only way to clear it is turning off and back on. It does it every time you try and take a picture.
5 Suggested Answers
SOURCE: blank film
I had the same problem. I think I finally figured it out. My problem was that the Shutter was in lock mode. In the manual book there is a section called "Shutter Lock." How to get it unlocked: While pressing the drive mode button (1), turn the camer on with the function dial (2); the data panel displays the status of the shutter lock. If it says "lock", you will need to do this process again to get it unlocked.
To find out where the buttons are, you will need to look in your manual -- page 53.
Hope this corrects your problem.
Posted on Sep 09, 2008
SOURCE: Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Posted on Nov 25, 2008
  • 12 Answers
SOURCE: Looking for a Minolta Maxxum 5 manual
It is a great camera indeed. Here is minolta's web page with a manual to download: http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Posted on Nov 12, 2009
  • 102366 Answers
SOURCE: 1) Minolta XG1 35mm Film
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Posted on Feb 17, 2011
I just got batteries for this camera and when i turned it on it worked perfectly. i turned it off opened the back just to look at it then closed the back. when i switched it back on i got "err" on the...
If there was a film in the camera and you opened the back, all the pictures you took got burned. You need to rewind the film take it out, put a new one in and try to turn on the camera. err should be gone.
Oct 20, 2013 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Nikon d80 camera shows err error, when shutter is pressed the amount of shots remaining, shows er07. shutter works, but no picture is taken. Bracketing sign is also on display and wont go off.l
failure of the aperture unit is the usual cause - usually the contacts for the phase switch have come loose from the gear. You can find info on this by searching for the problem on the internet, including how to repair it.
Apr 06, 2013 | Nikon D80 Digital Camera
Press shutter releas button for error are coming ,wat is the Problem
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR ' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR ' with a different Canon lens attached, then the camera should be serviced.
Nov 17, 2010 | Nikon D40x Digital Camera
I have err 99 any solution?
.1. Turn off the camera.
Does the "ERR 99' message appear? If it does, then the camera should be
Does the "ERR 99' message appear? If so, then the CF card is the most
camera body.
If the "ERR 99' message only appears when one particular lens is
If you see the "ERR 99' with a different Canon lens attached, then the
Jun 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 in canon 350D
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
camera body.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Konica Minolta Maxxum 70 QD with 28-100 lens 35mm Film Camera Logo
35 people viewed this question
Top Konica Minolta Photography Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
arjoy ceniza
arjoy ceniza
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
