Question about WYSE Winterm 3235LE (90202401R) PC Desktop
How to disable auto login on 3235le
3235le is set to auto login - I need to disable so I can login as administrator on the device
  • 3 Answers
Hit the ALT key and F4 while auto logon is counting down to cancel auto logon.
If you've forgotten the admin password you can perform a factory reset by holding down the 'G' key while powering the device on.
Posted on Dec 16, 2008
I have administrator on user name and cannot get
You didn't mention the Operating System you're running. But if you can't login to the Administrator account - you won't be able to add another user account. In XP, if there's no password set, you can login to the Administrator account by booting into Safe Mode. In Vista, Win 7, and Win 8 Administrator account is disabled by default. You can enable the account, and blank the password, by booting from a CD or thumb drive created with the following program: http://pogostick.net/~pnh/ntpasswd/
Oct 01, 2014 | Computers & Internet
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
Set up security
If you know the default username and password then you can login after reset the router. Reset the router using reset button. To get manual you can visit router manufacturer website.
If you want to set security then you can do the following steps:
->Change Default Administrator Passwords (and Usernames)
->Turn on (Compatible) WPA / WEP Encryption
->Change the Default SSID
->Enable MAC Address Filtering
->Disable SSID Broadcast
->Do Not Auto-Connect to Open Wi-Fi Networks
->Assign Static IP Addresses to Devices
->Enable Firewalls On Each Computer and the Router
->Position the Router or Access Point Safely
->Turn Off the Network During Extended Periods of Non-Use
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Nov 08, 2012 | Computers & Internet
My device manager is disable by administrator
You have to login with an administrator account to access the device manager. If you don't remember your administrator password then download a boot disk called "KON BOOT" boot with the CD, you will not need to enter any administrator password to login. Once logged in change the administrator password to whatever you want it to be.
Please rate my solution to show your appreciation!
For more tips visit my blog at http://thegeektweet.wordpress.com
Jun 04, 2011 | Microsoft Windows XP Professional
HOW DO I REMOVE THE GUEST ADMINISTRATOR WITHOUT BEING AN ADMINISTRATOR ON MY COMPUTER SO I CAN DOWNLOAD THINGS ON MY COMPUTER
You question is not that specific so i can't give you the specific answer, there're several ways to configure this settings, but it depends on the Operating system you are using. If you are using windows Xp, log off from the desktop and press Ctrl+Alt+Del simultaneously on the login screen (sometimes you'll need to press several times), a small logon window will pop up, type administrator on the username box and if a password was set with the administrator, key in the password, or if there's none, just press enter after typing the "administrator". After you are logged in with the administrator account, go to control panel - user account - create new - and create an account (any username that you want to give) with the administrator privilege (rights) {you should select Computer Administrator}. Again log off and login using the new username and password (if you've set a password). Now with that account, you can do anything with your computer. If it's not Xp then the problem is difficult being without the administrator's rights. If you have another account with administrator's rights, then you can disable the Guest account. Good luck Thanks for using FixYa.
May 30, 2010 | Computers & Internet
Purchased used wt9235le and don't know logon id or password,how do i crack
Hi, if it is similar to the 3235LE you can reset them by holding down the "p" key whilst powering on the device.
Jan 20, 2010 | WYSE Winterm 3235LE (90202401R) PC Desktop
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Can't login as administrator pc america RPE
use the software default or another login and go to employee settings. Admin was probably disabled. Re-enable it and try again
Sep 16, 2009 | Pc America Restaurant Pro Express
Wyse 3125 CE
when the terminal is logging of select ctrl-alt-esc and it will come up with login screen where you can just login as administrator
Nov 14, 2008 | WYSE V90 Network Terminal
Cannot get password for toshiba satellite A200-TR4
Passwords are setup when you first recieve the computer. What I suggest, is that you log in as administrator (at login screen hit ctrl+alt+del) administrator as logon, with no password. IF it says account disabled, then reboot to safemode, and log in as administrator (then it will take the administrator login *with no password) - once in, you can change users passwords *which is your logon*.
If this does not work, write back.
Mar 28, 2008 | Computers & Internet
WYSE Winterm 3235LE (90202401R) PC Desktop Logo
3,561 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
