Question about Sharp AR-C270 Color Copier
NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
I can't find out what the ip address is for my copier i just bought. I am trying to set up a network and need it's ip address. Its a sharp ar-c270. Thanks, Killer
  • 3 Answers
Custom settings, List print, Print test page, NIC Page.
Posted on Jul 27, 2007
Need a static ip address
First you go to machine network settings and then DHCP disabled.Now you can using static ip address.
Jun 29, 2011 | Sharp AR-M205 Copier
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Can't install
If you can ping its IP, you have that part correct.
What you may be having is a firewall issue.
If your firewall protection is not allowing an exception for that IP address, you can ping the machine, yet the data being sent will be blocked.
I have seen this several times in setting up printers, you have to go into your firewall and set up an exception for the IP address on your firewall.
I suspect that is the issue. Not uncommon.
Jan 16, 2008 | Sharp AR-507 Copier
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-C270 Color Copier Logo
474 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
