Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
The carburator is loose, can't get to bolt to tighten. how do you
The bolt that holds the carburator on is loose. how do you tighten it?
I bought a new one
Posted on Nov 21, 2008
Bearings working loose on h bracket
on your headset or on your bottom bracket? im assuming you mean your headset. easiest solution to fix that is to loosen the top bolt that holds down your headset, then loosen the two othe bolts located on your stem. with the stem bolts loose tighten the top bolt until you feel slight resistance when you turn the front wheel. then re align your handlebars with the front wheel and re tighten the two stem bolts. if its a persisting issue try using locktight in your star nut which is located under the top bolt in your headset.
Jun 03, 2012 | Mongoose Khyber Super
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
How do i drain old gas from the motorcycle
you will need to remove ur seat in order to get to the bolt or clip down that holds the rear of the petrol tank to frame.make sure the fuel tap is off & remove the fuel line going from tank to carburator then remove tank & empty the old gas out.there should also be a drain bung/bolt on bottom of ur carburator bowl,undo this let all gas empty out,then re-tighten & then reverse steps to put tank back on.Fill with fresh gas try start,check for any leaks & should be good to go!
Jan 04, 2011 | 2007 Yamaha XT 125 X
The steering pump belt was loose so I tried tightening the tensioner. The belt only got looser.The adjustment bolt seems to be stripped. What can I do to manually tighten it?
you tried to move the adjuster but didnt slacken the supporting bolts first ,sorry you will just have to renew it ,ir slacken the bolts holding the pump and then pull it tight with a crowbar then tighten the bolts again
Dec 17, 2010 | 2001 Mercury Villager
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Hand brakes are loose and need to be tightened so they will stop the bike. How do I tighten the hand brakes?
loosen the anchor bolt the hold both brake shoes against the wheel rim pull the cable tight and tighten the anchor bolt
Aug 07, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
Reverse workes sometimes
Is it a manual or automatic transmission?
On the automatics the two cables that interconnect above the transmission need to be set perfect for the transmission to pump pressure and engage the transmission.
Set it so the backside is fairly tight and the carburator isn't loose to the throttle valve assembly. Then loosen the front cable and pull it towards yourself until tight and finger tighten the adjustment bolts.
Now shift it into Neutral. Loosen the front and back nuts on the heavy shifting rod and center them again. Tighten them up. If you loose reverse loosen the front cable a tiny bit and you're done.
Jun 02, 2010 | 1991 Geo Metro
How do i tighten a loose screeching belt on an '01 accent gs 1.6L
The belt is adjusted by the position of the alternator. Loosen the bottom mounting bolts. Loosen the adjusting bolt in the top bracket & using a suitable lever, pry the alternator outwards until the belt is tight. Do not tighten it too tight. you should be able to deflect the belt down about 3/4 -1" when tightened. Hold the bar to maintain this tension on the belt and tighten the top adjusting bolt. Re-tighten the two bottom bolts. Check the deflection of the belt once more to ensure it is not to tight.
Mar 21, 2010 | 2001 Hyundai Accent
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
My steering column is loose on my 1977 cadillac. How do I tighten it up. It appears to be loose where it attaches to the dashboard.
there should be two bolts going through a bracket around the column. the bolts attach to the metal part ot the dash.
Dec 12, 2009 | 1976 Cadillac Deville
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
66 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
