Question about HP LaserJet 2420 Printer
Error code on hp 2420
I have an hp 2420 it gives an intermittent error of 49 3C1A can anyone help
  • 274 Answers
It's a communication or hardware error.
It's best if you update your firmware. Get the files from the link below...
HP 2420 Firmware Updates
Posted on Nov 20, 2008
Error code e000007 canon 2420
Dec 06, 2012 | Canon Office Equipment & Supplies
HP Laserjet 2420 error 41.2
hi i found the problem in hp laserjet 2420 printer error 41.2
Mar 19, 2012 | HP LaserJet 2420 Printer
I have a HP Laserjet 2420 and show error code 41.03.00
Un expected paper too lengh, check papers are loading one by one or more then one at a time loading in side?..If multi papers are loading, replave separation padClean all paper path sensors..
Aug 19, 2011 | HP LaserJet 2420 Printer
Hello....i have HP LaserJet printer 2420. when I print it gives me 52.00 error and not printing at all
52.00 error is not good.
If you tried powering off and on and that didn't work, a tech is going to have to look at it.
Problem could be the laser/scanner or the engine control board(ECU)
May 26, 2011 | HP LaserJet 2420 Printer
Does it give a 49.FF95? As their is no such error code "FF95" for a HP 2420. However I've seen 49. XXXX error codes before (XXXX meaning weird Alphanumeric Characters and numbers). This type of error code you can try a couple of Items:
1st - Perform a Cold Reset:
1. Turn the printer off.
2. Hold down the SELECT button, and then turn the printer on. Continue holding down
the SELECT button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted.
4. Press the SELECT button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values
If the machine still comes back to the Strange FF95 error I would start with the replacement of the formatter,
Part Number for the Formatter:
Network versions Q3955-60003
Non-network versions Q3953-60001
Hope this helps..
Feb 25, 2011 | HP LaserJet 2420 Printer
My printer is giving an error message..."error 57.03"to continue turn on then off....i do it to no me
This is a Fan issue you have 2 of them one on the front right side and one on the left. if you remove both covers see which one is not working
Now if their are both working then you will need to replace the ECU (Engine Control Unit).
I've attached a link that shows you how to remove the covers off the 2420 it's a pdf file .
And the Left side cover will need to be removed to access the other fan.
Oct 18, 2010 | HP LaserJet 2420 Printer
Hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Nov 20, 2008 | HP LaserJet 2420 Printer
LJ 2420 service error 49.2604
A critical firmware error has occurred. Hp suggest reseating memory modules and upgrading the firmware, but i've found in the past if by turning it off and on a few times doesn't cure it the formatter board needs replacing (quite common on this model)
Sep 01, 2008 | HP LaserJet 2420 Printer
HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Apr 15, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
424 people viewed this question
Ben Johnson
