Question about ASUS P5GD1 Motherboard
Myself can't install win_xp sp-2in my pc
I was tried all the setting in setup but it is not work after loading after setup file
  • 59 Answers
THE INSTALLATION OF WINDOW SERVICE PARK GOES LIKE THIS. IF YOU ARE USING WINDOW XP WITH SP1 THEN YOU CAN UPGRADE IT WITH SP2. IF YOU ARE USING WIN2000 FOR INSTANCE YOU CAN NOT IINSTALL SP1 OR 2 OF WIN XP ON YOU OS YOU MOST FIND SERVICE PARK FOR WIN2000 TO UPGRADE AND IT ALSO HAS TO START FROM 1 TO THE LATEST VALUE THAT IF YOUR WINDOW2000 HAS SP1 YOU WILL START WITH 2 YOU CAN JUNP TO SP3 OR 4.
Posted on Nov 20, 2008
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
Unable to reinstall XP after Vista upgrade
If u have win. vista installed in ur laptop than u cant install win xp............if u install win.xp than ur vista will b dissappear from boot menu
if u want to overcome this problem than buy a software VISTABOOTPRO
and install it in XP it will help u
OR u can ask me for free soft.....
Sep 12, 2009 | Compaq Presario Notebook
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
No OS FOUND on my Pavilion a1600n (preinstalled Win XP) can I install Win XP Home Edition I bought. My recovery disk will not work.
boot with win xp setup disk.
set first boot devic as cd drive then insert win xp disk into it.
then follow wthe procedure .try to repair os win xp .if it is not found bye setup go to recovery console run this command: CHKDSK /r
then wait untill cmd probmpt.
ten u can repair win xp
Sep 15, 2008 | Computers & Internet
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Fdc corrupted
That error message means. You must have tried to boot up to a floppy diskette. The diskette ( 's ), were made with a defective floppy drive.To re-download the Setup Disks for Floppy Boot Install of Win XP click the link below:
http://www.microsoft.com/downloads/details.aspx?familyid=E8FE6868-6E4F-471C-B455-BD5AFEE126D8&displaylang=en
Option if you have a cdrom in notebook & a real Win XP CD. Put the win xp cd in the cdrom drive. Start the Pc laptop & press the F8 key every two seconds. Windows will display a boot up option menue. Choose the cdrom. Win XP will start the installation.
Feb 11, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
ASUS P5GD1 Motherboard Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
