Question about HP Computers & Internet
Can't change resolution on older monitor M50
Won't move above 640 x 800 pixels
  • ldickinson Nov 20, 2008
    Yes, that's what I thought too. I get confused as to what drivers I should update to fix the problem. Would I update the driver for the Display adapter, or the driver for the computer monitor?
    Thanks in advance!
    Scholar:
  • 135 Answers
It seams your video card is not properly install. If you have more option greater then 640*800 then it means your monitor not support above resolution that you mention.
If problem is not this which I mention then please reply to this thread with explanation.
Posted on Nov 20, 2008
  • Naveed khan
    Naveed khan Nov 20, 2008
    OK
    You have to update the driver of Display adapter.
    If you didn't know about your display adapter then do this...
    Right click on desktop
    Go to properties
    Move to sitting tab
    Click advanced button
    Now click adapter tab
    There you will see your Display adapter name version
    Do to your manufacture site and download updated driver for your display card.
    I hope this will help you, don't forget to mark as answer my thread.
Blurry text
LCD monitors do best at their native resolution. There might be 2x2 pixels per spot at that resolution. Once you change the resolution, you might have 2.7 x 2.7 pixels per spot (merely an example). Although a resolution might fit well, at 3x3 or 4x4 pixels, all the other resolutions might look out of focus as each character bleeds over into an adjacent pixel.
The 16:9 aspect ratios are the only ones that will work correctly with this monitor; others will show black at the top and bottom or left and right, or images will be too tall or too wide.
The resolutions you should try are 1920 x 1080, 1280 x 720 or 800 x 600. When I look at resolutions available for my 16:9 ratio monitor, those are the three that are bold.. others are available, but would not show the high quality display.
There are also buttons on the front of the monitor to adjust the display left/right, up/down, re-size, focus, brightness, etc.. A change there could make a difference too.
Oct 30, 2013 | Westinghouse Electric L2220HW 21 inch LCD...
Screen resolution cannot go up from 1024 * 728
go into control panel,click on display.press open,you should see a window that says DISPLAY PROPERTIES.click on settings.to your lift it will say screen resolution.move cure on the scale to the right until you get the resolution you want.after selecting the pixels to the level you want press OK.and exit out of control panel.now try to see if it is enough,if not do the same above steps again.(GOOD LUCK0
Sep 10, 2012 | Dell Computers & Internet
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computers & Internet
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
How do i change the pixels
A pixel is a single point in a graphic image ie on the monitor. You can't change the pixels because it is the inbuilt hardware in the screen of your monitor.
You can only change the resolution of the screen. You can change the resolution from your Display properties -> settings tabs.
Hope it helps.
Oct 07, 2010 | Individual VideoShow Expressions (3314)
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
Resolution problem in Cricket 07
you need to check if your computer monitor supports resolution above 640 X 800 pixels or not, if you have a windows operating system you can check this by right clicking on your desktop ->Properties -> Settings -> Screen Resolution, check here by moving the slider bar what is the maximum video resolution supported by your PC
Also check if your computer meets the minimum requirements required to play EA Cricket 07
Apr 07, 2009 | EA Sports Cricket 07 for Windows
My screen resolution wont go above 640x480 pixels,16 colors
that probably the highest ur screen can go unless u update ur video card u can purchase some really good video cards at Best Buy or Wal mart Looking to help u Shaun
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
