Question about Epson Stylus CX5400 All-In-One InkJet Printer
Scanner won't scan
The scanner bulb is burnt out, where do I get another bulb?
  • 849 Answers
The computer spare parts/accessories reseller will provide u new bulb for scaner.
Posted on Nov 20, 2008
How do I get it off manual scan uniden bc72xlt when i turn it on it won't scan. thanks need help.
these scanners are a little hard to operate i have one of these it took me a while...Ok its because you have it on hold.when you turn your scanner on press your scan button.and your scanner should start scanning...
Jul 09, 2011 | Uniden BC72XLT Handheld Scanner
Unable to send, copy or send fax
Sounds like the scanner bulb is burnt out or it's not able to move the scanner sled.
It should be saying "scanner error" as well. (and I think you meant unable to scan, copy or send fax)
No fix unfortunately other than getting a replacement unit (which I believe now is the 8500 premiere)
If you need a replacement, your timing is good, they are $200 off right now, and selling for $299.
Your unit as it stands still makes a good printer and will receive faxes, and you CAN send a fax as long as you do it from the computer.
Feb 28, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Looking For Replacement Display Bulbs......
the bulbs most likely not bad I have always had bad capacitors on the inverter board you should be able to see the capand wherethe bad one as the top will be deformed or/buldged replace all the deformed capacitors and see if that solves your problem you have,
May 16, 2010 | Uniden BC895XLT Base Scanner
When it scans it leaves a black line on the document and on the computer screen.
The black line is either caused by dirt build up on the scanner glass (clean the scanner glass) or one of the bulbs on the scanner lamp is burnt out.
Mar 24, 2010 | Lexmark X4875 All-In-One InkJet Printer
Documents are not sharp almost like double vision
Since it takes several scans to get a clean scan, this would indicate the bulb as the bulb warms up over time and gets brighter. If it were a problem with the optics, then the result would be the same on each scan. There are several parts houses on the internet where you can purchase scanner parts. Type in Canon 5200F scanner bulb replacement into your search engine and you'll find several. Compare prices and shipping for your part to select the best choice (also check their return policy in case you receive the wrong part).
Mar 10, 2010 | Canon 5200F Flatbed Scanner
The scanner is not scanning in photo scan mode and
that's hardware related problem, you need to open the machine and lubricate all moving parts specially in bulb image receiver side.
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
Hp photosmart 3110 scanner problem
scanner moter is involved in it .. as it is responsible for moving the scanner bulb ...
Oct 29, 2009 | HP Photosmart 3310 Printer
Bulb burnt out
you couild try here
If you can'f ind it listed you could always contact them.
Jul 29, 2009 | Visioneer PrimaScan Colorado 2600u Flatbed...
Problem when scanning
If it is under warranty, contact HP.
Believe it or not, there probably is something in your scanner. Often times it is a very small piece of dust/fiber. If you are using the document feeder, the check the small piece of glass as the scanner bulb remains stationary and the paper is fed by. If you are laying the paper on the glass and scanning, then you will need to look at the scanner bulb itself. Run a scan with no paper and see if you see anything. If not, you can try to take it apart and clean the bulb (but do not touch the bulb with your bare fingers), with a light wipe of a tissue. If after cleaning, it either moves or goes away, then it is dust related. If it remains in the same position on the page, then there is a scanner bulb problem.
Nov 20, 2007 | HP LaserJet 2840 Printer
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
Epson Stylus CX5400 All-In-One InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
