Question about Nokia 6600
Memory card I'm formated my 6600's memory caed in my PC. After that ,In the gallery when I change into memory option It shows (memory card corrupted). My phone is infected by virus.I formated the phone also(now phone is OK) How can I solve this Problem?
  • 283 Answers
Format your memory card at your cellphone. Go to menu then to select extra. clickthe memory card option thenselect format. Thank you...
Posted on Nov 20, 2008
I cant see any photos which are there in memory card in the gallery.
If you cannot see the pictures on your phone, that is on the memory then you need to format it with the steps below but before that connect the memory card to your pc an save all data there first. when finished with the format replace them back to the phone
NOTE: Format the memory card if you forget the memory card password. The device will allow you to format and erase the memory card password without asking for the password during the formatting process.
To format the memory card:
1. Press Menu
2. Select Applications
3. Select Office
4. Select File Mgr.
5. Select Memory Card and press Options
6. Scroll to and select Memory Card Options
7. Scroll to and select Format
8. Select Yes
NOTE: Format the memory card if it intermittently malfunctions (e.g. errors, file corruptions)
The Formatting option will properly configure the memory card for use with the phone.
Dec 05, 2010 | Nokia 5230 Cell Phone
Nokia n72... database corrupted.
You got a corrupted memory card inside your phone. Format it. Go to tools folder and then select memory card. Press option and then select format.
Mar 28, 2010 | Nokia N72 Cellular Phone
Reformatting my memory card
Get a card reader for your pc, then take the memory card out of the N70, and into the reader. It should show up in my computer, at which point you can right click and press "format". Press start, and wait. Once this is done, safely remove hardware and put back in phone. Warning! This will destroy all content on card!
Hope this is a help,
Jun 03, 2009 | Nokia N70 Cellular Phone
Memory card problem
Promblem Regarding Memory Card of 6600 Nokia. ------------------------------------- 1). Format the memory card by the phone using "format" option available in memory card "options".
2). If still same problem appears, then format it through pc-suite software, or through memory card reader which available in market (this process is by using PC).
3). If still same problem appears, then try with a new memory card.
Because it depends on your handset. After inserting a new memory card, if the same problem appears please contact your nearest "NOKIA CARE".
All the Best....
Thanking you.
Mar 02, 2009 | Nokia 6600
Format the Memory card once and try again, there is some applications installed on the memory card which will not allow you to use bluetooth.....
Nov 07, 2008 | Nokia 6600
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
Nokia 6600
It is necessary to format your phone, because system files regarding your phone boot sector seems got corrupted. There is not enough room in your RAM it leads to your phone at this status. Take important data backup, remove MMC and enter the press four keys i.e. 3.*,green send key and power on key together for sometime and hold it for sometime. Your phone screen will indicate "FORMATING". Your phone will get formatted, then switch off and on it again as usual . Remember to scan your MMC with a good anti virus before inserting it back in phone. During formating don't remove battery and do this process only with enough charged battery. You will be able to send your message then. Do vote this solution....
Jan 10, 2008 | Nokia 6600
Nokia 6600 Bluetooth, gallery problem.
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Dec 07, 2007 | Nokia 6600
Start up problem
hie Chaitu,to solve your problem,you have to do the following. Restart your phone. If you have a memory card in your phone,scroll to the card and open it and it will show you the card name,capacity,used space and free space.Then press options button and select back up phone memory and proceed with the commands to back up your phone memory. note:make sure you have at least 6000 kb free space in your card. when the back up is complete,switch off your phone and format the phone. To format the phone press the following 3 buttons at once while your phone is off (*+ button + number 3 button and a call button )so try to switch it on while holding those buttons and it will start formatting and if it starts formatting release the buttons and wait untill it finishes the process and it will starts automatically and then try to restore your data from memory card. in so doing you have solved the problem and if anything let know. Thipa
Aug 25, 2007 | Nokia 6600
Nokia 6600 Logo
56 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
