Question about Lexmark Office Equipment & Supplies
Not a problem now but more of a question im a first time user and i was woundering whats my fax number? i have a cell phone but a home phone. what do i do?
    Genius:
  • 2,120 Answers
Call your cell phone from the fax machine. The number will show up in the display.
Posted on Nov 20, 2008
Ok im trying to transfer my work phone to my cell phone so i can go home and not have to sit up here all night. and i cant figure out how to do it.
  1. Pick up the receiver on your work phone and wait to hear a dial tone.
  2. Dial *72 on your work extension phone keypad. You may hear a series of four beeps that indicates the system is ready for you to enter the phone number to which your calls will be forwarded.
  3. Enter your cell phone number including the area code on the keypad of your work extension phone.
  4. Hang up the receiver on your work phone.
  5. Test the call forwarding by dialing your work extension phone from another phone. Your cell phone should ring. If it does not ring , repeat Steps 1 through 4.
Read more: How to Forward Calls From My Work Extension to a Cell Phone ' eHow.com http://www.ehow.com/how_6239419_forward-work-extension-cell-phone.html#ixzz16L3AMu3K
Nov 25, 2010 | Office Equipment & Supplies
I got a fax number from telstra and got told that my home phone wouldnt be interupted if they come through the same line my home number is different to the fax number but my home phone wont except messages...
both the numbers should be same otherwise the fax machine will not work properly ..............you have to ask the person who gave this machine for a change of number
please rate me
Jul 14, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Ricoh 1013F Fax Line answering phone calls
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
Can I fax using my home phone number
yes! you can use any phone line to fax. if you want to receive fax, then you need to setup the machine to receive fax after the pre-define number of rings, and your home phone number.
Jan 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Want to FAX with My MagicJack(VOIP) using a standard FAX machine
holy ****, just google 'magic jack fax' and you'll get all the info you need. digital, analog, who cares, just do it.
Jan 01, 2009 | Computers & Internet
My home link system built in the sun visor of my 1996 jeep grand cherokee
Hi, there is no green button, i just bought the same vehicle,and i programed my entrance gate to the home link and worked the first time,all i did was hold my remote right up to the home link and pressed the first button and the remote button the same time until the red light flashed rapidly,and it worked just fine, hope that works
Dec 26, 2008 | 1996 Jeep Grand Cherokee
Fax modem
The best solution is not to need a fax/modem. Send and receive faxes via internet.
This program was PC Magazines editors Choice:
http://home.efax.com/s/r/efax-brand9?VID=33675&gclid=CL_th9ybypYCFQOIFQod1iRdyg
This way you don't need a phone line/ tying up your phone line etc..
Oct 28, 2008 | D-Link DFM 562E (dfm-562e) Modem
Samsung sf-340 user manual
Link to SF-340 User Manual:-
http://downloadcenter.samsung.com/content/UM/200609/20060925101938281_SF-340series_English.pdf
Reason you couldn't find it on Samsung website is they have it under "Multifunction Printers". ....?!! don't ask me!!
Gingan
Aug 27, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Trying to fax
lilman1,
it means you may have dialed the wrong number.
The fax machine your calling did not pick up. You can test the above by. Using your home phone or cell phone & call the fax number your trying to connect with. You'll know if it is a fax machine by the tone you hear.
Dec 19, 2007 | HP OfficeJet D135 All-In-One InkJet...
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
