Question about Garmin nuvi 200W GPS Receiver
GARMIN NUVI SCREEN UNRESPONSIVE/LOCKED?
I WENT TO THE MOVIES WITH MY GPS [GARMIN NUVI 200] IN IT'S CASE [LEFT ON] I MUST HAVE PRESSED ON THE CASE AS I HEARD BEEPS FROM INSIDE. WHEN I WENT TO USE IT IT IS UNRESPONSIVE AND THE LETTER "N" IS LIT UP [HIGHLIGHTED]. PLEASE HELP ME GET IT BACK TO GOOD HEALTH. I CANNOT TURN IT OFF EITHER, NOR CAN I LOCATE A RESET BUTTON.
  • KSJUNKMAN Nov 20, 2008
    I WAS JUST JUST GIVEN THE ADVICE TO REMOVE THE BATTERY ETC!. WHILE SEARCHING MY GARMIN MANUAL I FOUND THE RESET BUTTON LOCATION, PRESSED IT AND EVERYTHING IS BACK TO NORMAL. THANKS KEVIN. I SHOULDN'T HAVE PANICKED BUT I DESPERATELY NEED THIS LITTLE BOX OF LOGISTICAL KNOWLEDGE AS IT'S MY NAVIGATOR WHEN ON THE ROAD. THANK YOU.
    YES, THANK YOU. IT WAS A SIMPLE FIX BY PRESSING THE RESET BUTTON THAT I INITIALLY COULD NOT LOCATE.
    Sergeant:
    Champion:
  • 435 Answers
Hold on the power button for few seconds and see it works.
Posted on Nov 20, 2008
    Sergeant:
  • 306 Answers
I think u need to try updating the firmware... see tis..
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  • AbdulRahiman S Nov 20, 2008
    else the only way is just send it back to garmin. since they are very prompt with repairs, and usually you'll get your unit back within a week. ui may try out tis..
    Brigadier General:
  • 6,966 Answers
Initially, pls try a hard reset. This would be a small button under the serial number. Should this not be sufficient pls try a system reset which of course would revert the unit back to factory default and remove any and all user settings and configurations. Pls see this link for the general procedures. Additional reference may be found here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Genius:
  • 1,847 Answers
Try take the battery out and turn of the GPS. and restart it . hope it will work.
let me know the status...kevin.
  • Legin Varghese
    Legin Varghese Nov 20, 2008
    and also try to reset the unit....The unit does have a small reset button on the lower beveled edge. ..kevin
Updated Garmin Nuvi 200 with Garmin Express. Now the Garmin reads "No detailed maps found to support routing". I pressed on the screen until this mesage left the screen and returned to the regular start...
Time for an update. Go to Garmin.com and get it done. If you haven't done this for a while you might get a new OS too. The older models use a lot of the memory for the updates and might need to download a smaller range map.
Nov 02, 2013 | GPS
Garmin nuvi 255w flashes on & off
I did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars
Apr 02, 2013 | Garmin nuvi GPS
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
I just bought my Garmin Nuvi 200 and just stays black screen?
My Garmin 200 did the same on two occasions. On the bottom to the left of the serial number is a tiny reset button. Press that using a pencil point and all will be reset. And you don't lose any map data, so don't worry!
Apr 27, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 200 Cannot unlock maps, it says
To answer your first question: The screen is currently locked. Slide the power button all the way to the left
For your general question, a Google search for "nuvi 200 instruction manual" produces 43,000 results
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
GARMIN 200 LOCKED
how do i get a passcode a for a garmin nuvi 200 if its lockd and u forgot the code and u cant send it back to da company
Jul 13, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
18 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
