Question about Sony VAIO PCG-K35 Notebook
Speaker problem my speakers are very low i can't hear anything and i checked its not on mute and everything else is working fine it's turned out to the hightest volume but at same time there is no sound.
    Sergeant:
    Champion:
  • 258 Answers
Check if the sound device is selected on the sound and audio devices located in control panel if you found no audio device then i think you may have to install the driver but first check if its properly detected on your system
Posted on Nov 20, 2008
  • Efren Javier
    Efren Javier Nov 20, 2008
    check also if the speaker jack is inserted in the right slot it could have missed the speaker slot
How to turn off mute from receiver
I can't find a mute button on your receiver, but there are a few things that can avoid getting sound to your speakers.
Before trying anything, please turn the volume knob down to a very low volume. It the amp is set to a high output and the speakers get everything with a bang, they could be damaged seriously.
The amp can manage to sets of speakers. A and B. The can be switched on separately, both or non. Make sure the group you connected the speakers to is engaged, or to test, switch on both.
Then there is the headphone plug. If a plug is in there, it will kill all sound going to the speakers. Also when the contacts in the socket are oxidised, this can cause no sound coming through.
So if you have a sound input, on port 1, a CD player, and you select CD. You should hear sound coming out of the speakers if you select A and B. Eventually you can press in a headphone in to listen if there is sound in the amp.
Oops I just found another thing. You can connect / disconnect pre and power amps on the back of the amplifier. Look on the part I add here from the manual and check if the bridge is in.
Jun 25, 2014 | Yamaha RX-V990 Receiver
Toughbook CF-53 Speakers won't work
Have you tried rebooting? In the Control Panel, select Sounds, select Speakers as default, remove headphones plug from jack.
May 24, 2013 | Computers & Internet
NO SOUND ON MUSIC PAYER CAN SEE ITS PLAYING CANT HEAR ANYTHING
hi,
try to check maybe your phone is in mute mode or the volume is set too low.
if playing also ringtones, games or your phone doesn't rings when somebody calls you, this could be the problems below.
if it is not in mute mode then most likely it has a defective speaker or loose connection to the speakers. you can check its connection if inside if you can open your phone. but try only opening your phone if you know what you are doing, you might worsten its problem. you can locate the speaker inside, it is like a small speaker and check if it has abnormalities. other than that, don't touch anything else.
(if you have a multi-tester, you can check the speaker itself by placing the red and black probe to each terminals of the speaker and if you hear a scratching sound on the speaker then your speaker is good. if none, then an open defective speaker.)
(WARNING: only open if there is no more warranty on your phone cause opening it can cause your warranty to be void)
dont forget to rate me. Thanks...
bst rgrds
John
Jan 05, 2011 | Samsung Omnia Pro B7320 Smartphone
My speaker is on but I am not hearing any sound i am playing music but not hearing anything it was workin fine all the time.
Follow theese steps:
Check the cables first.
Check if the volume button is working.
Check the volume/audio control panel on your taskbar (this happens if it is turned on mute).
Check the drivers
Aug 05, 2010 | Computers & Internet
Why speaker is not working ?
first off, make sure everythings plugged in right
speakers plugged into audio out or headphone out on back of computer, power is on, and both speakers are plugged in, then check the muting, if its muted un mute...
if its not muted
try muting then unmuting, i sometimes have that problem...
if all else fails, try turning off your computer then waiting 5 mins, and turning it on, if sound works, then great, if not try a set of headphones you are positive work, plug them into each plug theyll fit in on the front and back, or sides of your computer, if not, chances are you have a broken soundcard...
or a software conflict, did you install anything lately, try uninstalling...
Jan 06, 2010 | Audio Players & Recorders
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
System turns on but only hear feedback fomr speakser no sound
do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
May 22, 2009 | Pioneer VSX-D409
My speakers dont sound
If you have an amp in your system, I would check the preamp connections, as well as the +12V power, remote, and ground connections to the amp. It's possible the amp is not turning on or the RCA preamp wires got disconnected.
If there is no amp involved, the connector that connects the speaker wires to the head unit may be loose or some sort of "mute" may have been inadvertently enabled.
Mar 26, 2008 | Car Audio & Video
No sound through speakers
are you using RCA outputs(the round red and white plugs)? if you are then your amp is not turning on and if you are hooking up speakers to your RCA's (low level) then you will not hear any audio the signal is to low. would need to know more about how you checked the ic power?? one could verify an output ic by hooking up an amp since the RCA audio signal is picked off just before the output. if the low level works but the speakers do not then you have a bad output. anything else an o-scope would be handy.
good luch stereo tech (genesisportland@hotmail.com)
Feb 03, 2008 | Alpine CDE-9881 CD Player
Sony VAIO PCG-K35 Notebook Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
