Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
One of the Burners does not light.
The left rear burner does not work and it is not the electronic igniter as there is spark there. The burner is not getting gas. All the other burners work fine.
  • 3 more comments
  • Richard Sermon Dec 23, 2006
    What a grat web site and Rotu is indeed a guru! His solution is easy to understand and i am going to attempt the repair myself. I may submit another problem if i cannot figure out how to proceed. Thanks for the help.
  • tropical63 Jun 29, 2008
    3 burners won't lite but when one of the burners that do lite, is in the ignite position all ignitors ignite at the same time.also when one of the 3 burners that are able to lite is in use the burner that also works will not lite at the same time. thanks for your time. Confused
  • akorbel Nov 20, 2008
    My rear left burner on my Thermador RDFS30 cooktop has never worked. The electric ignition sparks but no gas. I have a day off to try to fix the problem and it's very inviting to put a wrench on the hexnut and turn it or try to remove and clean it, but I need advice first.
  • Anonymous Jan 29, 2009
    Left rear element sparks , but gas clearly is not coming out of this burner. I will check out the 2 solutions suggested by Rotu.
  • Anonymous Mar 12, 2014
    When plugged back in the electronic ignition is not working.. There is gas.
I have the same problem and just took the cooktop apart to investigate. I disconnected the solenoid lines from the simmer controller (that is located under a metal guard to the right side under the burners) and checked them with an ohmmeter. It reads an open circuit, which suggest the solenoid is bad. When I turn the control knob on, I also read about 100V DC on the corresponding solenoid terminals of the simmer controller. I was surprised it was that high for a DC voltage, does anyone know if that is correct? I would hate to spend $90 on a replacement solenoid valve and then have it blow because the controller is putting out too much juice.
Posted on Feb 20, 2007
  • 1 more comment
  • alex Stahl Feb 20, 2007
    I have the same problem and took the cooktop apart tonight to investigate. I disconnected the solenoid lines from the simmer controller (that is located under a metal guard to the right side under the burners) and checked them with an ohmmeter. It reads an open circuit, which suggest the solenoid is bad.
    For now, I have bypassed the solenoid and the burner works again but without the XLo feature.
    Following up on my recent post...I found wiring diagrams at appliancepartspros.com and saw that there is a switch in series with the solenoid. Hmm, maybe the switch was causing the open circuit reading...
    This switch is part of the potentiometer that slides over the burner control valve shaft. I took that apart and found that the switch contacts were dirty, cleaned them, and now it's all working again! No expensive solenoids or controllers to replace after all, yay!
    The construction of the pot makes it very likely that if you clean the glass front panel by pulling the knobs off and spraying the glass, the cleaning spray will hit the pot (and possibly carry some gunk with it). I'll be a lot more careful from now on not to let anything get inside the hole around the shaft that the knob attaches to!
  • David Green Mar 16, 2014
    Alex, how did you bypass the solenoid?
My middle rear XLO burner is not working. You can order a Thermador simmer control kit with 2 XLO potentiometers and the ignition control module for about $200 or individual potentiometers for about $20. You have to take the top off to replace these. The potentiometers fit around the valve stem below the knobs. They probably got liquid in them when you took off the knobs to clean. It may be possible to clean the contacts on the old one. New, improved part is Bosch #422748 potentiometer for most models with XLO burners. Don't mess with the gas lines and solenoids.
Posted on Jun 19, 2009
I have the same problem. Left rear burner, no gas. It is the XLO burner. I think its one of 3 things as mentioned below a) Burner Valve b) Bad gas solenoid or Bad gas controller. Not sure how to get started....Any help would be greatly appreciated.
Posted on Jan 30, 2007
  • 175 Answers
There's really only three things this could be if the spark igniter is working. The burner valve is broken internally and not letting gas through, or the burner cap is not on correctly and so the gas mixture is wrong and won't ignite. Usually the burner top just gets set askew and needs to be righted so the burner can work properly. If in fact there is no gas at all coming out, you will need to replace the burner valve. The third thing it could be is only if you are having this problem on one of the burners has the X-LO feature (turns the flame on and off in simmer mode) it could be a bad gas solenoid, or controller. These X-Lo systems are quite complicated and it may be worth your time to pay a thermadore servicer to check it out if its not a simple fix. Hope this is of some help.
Posted on Dec 21, 2006
Why would the left burner activate the right igniter?
Sometimes a lot of the holes in the burner get plugged. I use a toothpick to clean them out.
Hope this helps.
Mar 20, 2015 | Kitchen Ranges
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador over two left burners will not provide gas when knobs are turned. Also the oven will not light and the igniters on all burners will not spark. The electric is good to the appliance oven fan
You have multiple problems! First the single igniter that fires in all of the burners is either broken or disconnected electrically. Second, your gas lines or nozels at some of the burners are clogged. Check for cloggs by using a match as you light ONE BURNER AT A TIME...If they all light you only have the electronic igniter to troubleshoot...Have a repairman check it out for you if you don't feel confident with gas!
Dec 21, 2012 | Kitchen Ranges
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2010 | Kitchen Ranges
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Burner will not ignite.
facing the spark ignition, the burner has small holes that need to be clean, those holes are going down on the side of the burners, take a look a the ones that are working so that you can see the small flames going down facing the electronic pilot call the spark ignitiong, you can take a safety pin or a paper clip and clean them. many times the ignition is between the front and rear burners, it's where the spark ignite the burners.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric start gas range
You either have a short in your electronic ignition or the ignition board is defective. Check the wiring to the ignition board for shorts. also check and make sure you ignitors are well grounded.
Dec 08, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,305 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Steve Allison
Steve Allison
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
