Question about Refrigerators
Refrigerator motor runs constantly
My GE refrigerator motor runs nearly all the time; only rarely does it turn off, and that's not very long. I've checked the door switch and nothing happens. Moreover, when I adjust the thermostat even to the highest level, there's still only water - not ice - in the ice tray. I am however able to turn it off with the thermostat. The model number is: TBX14SAXKRWH
  • Anonymous Mar 30, 2009
    SIde-by-side GE Refrigerator/freezer is cold but runs constantly.
    Top Expert:
  • Refrigerators Master
  • 52,156 Answers
Door seal problems and incorrect settings will make the unit run continuously
fridges should be set around 31/2 to 4 and freezers around 3-4
if the freezer is too cold the difference between on and off is the amount of thermal leakage i the insulation
so that means if the setting for the freezer is at max, then the temp at full cold is equal to what is being lost and so it runs all of the time
if however the setting is only at what is need to keep frozen then the loss through he insulation can be for a longer period of time so the unit has a chance to turn off
same for the fridge but the setting can be a bit lower depending on the door cycles, period of time the door is held open and the ambient temperature
The saying ---know what you want before opening the door really does mean how long the unit runs for to recover the temperature
Posted on Sep 16, 2017
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
Sea Breeze
  • 4655 Answers
SOURCE: leveling refrigerator
You should never try to level the refrigerator completely as the doors may no shut on the own properly. I have added a link below that can help you address the problem and some other situations that occur with refrigerators, Go to line 7. Hope these help, Thanks, Sea Breeze
http://www.applianceaid.com/frig-doors.html#pops
Posted on Nov 02, 2007
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
  • 415 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
My fridge motor is running constantly although I’ve set the temp control to med to warmer.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/64---/Refrigerator-runs-constantly
This link should take you to several reasons that this may be happening....
Good luck in trouble shooting your issue. You may get lucky and just have dirt/lint buildup on your coils underneath the fridge which is pretty easy to fix yourself.
Jan 08, 2018 | Refrigerators
My GE side by side refrigerator, model TFX25ZPit runs continuously, does not shut off, how can I fix?
My advice is usually to start simple. Take the bottom cover off and vacuum the coils that are probably covered with dust. That will help your refrigerator function better.
According to DoItYourself.com:
"Troubleshooting a refrigerator that runs continuously requires an understanding of how the refrigerator works. By definition, a refrigerator is one of the few appliances within your home that has to run on a continuous basis. If the refrigerator is not running, it will not be able to keep food cold, which will lead to spoilage and waste. The way refrigerators are built to run on a constant basis, they break down on an infrequent basis.
When a refrigerator experiences problems or seems to be breaking down, there are some steps that can be taken to troubleshoot the problem. A continuously running refrigerator is indicative of a problem with one of the components within the refrigerator that needs to be assessed in order to determine the proper fix. In order to properly troubleshoot problems with your refrigerator that runs continuously, an understanding of how the refrigerator works is in order.
Condenser and Evaporator Coil The refrigerator consists of a condenser coil and an evaporator coil. It is kept cold by a liquid coolant that is pumped between the condenser and evaporator through the use of a compressor and motor. The coolant moves from the condenser where it is cooled into the evaporator. The condenser coils inside the refrigerator can be seen on the outside of the appliance while the evaporator coil is located inside the refrigerator.
The Role of the Heater and Thermostat Frost and condensation rarely builds up inside the refrigerator. A heater inside the refrigerator melts any frost that may occur inside the refrigerator long before it ever appears. This melting of frost takes place at various stages inside the refrigerator. After the melting process that takes place with the heater, the thermostat is engaged to set the refrigerator at its proper cooling temperature, keeping frost from building up.
Identifying Specific Problems Most of the parts that make up the compressor and evaporator units inside the refrigerator, consisting of thermostats, the heater, condenser, fans and various switches, are easy to identify and replace. The trick to troubleshooting the refrigerator that runs continuously is to listen for noises and sounds that occur and seem unusual to you. A loud running refrigerator or constant churning of ice when the ice makes is not engaged can indicate problems with the motors or compressors that need to be replaced immediately.
Addressing Problems with a Continuously Running Refrigerator Nearly all problems that can be uncovered by troubleshooting your refrigerator can be fixed by most every do-it-yourselfer. Those problems with your refrigerator running constantly that involves the coils located outside or inside the refrigerator should be handled by a professional repair technician. This is because the coils contain the refrigerant that can be dangerous if you are exposed to it accidentally during the course of a repair. If you notice a problem with the refrigerator or a constant running that seems to be getting progressively worse over time, the best way to address the issue is to isolate the problem and fix it."
Apr 23, 2015 | Refrigerators
Temperature issues in GE Profile Refrigerator Freezer, what to do?
Sounds like an inefficient compressor or possible overload/relay issue
Jul 25, 2013 | Maytag MZD2768G Side by Side Refrigerator
Freezer not cold but refrigerator is barely. Motor runs almost constantly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | GE GSH22KGR Side by Side Refrigerator
Motor runs constantly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Oct 08, 2010 | GE Refrigerators
GE top freezer refrigerator fan rattles constantly
It is mounted properly, it is probably a bad bearing in the fan motor and/or the blade is loose on the shaft. Replace the motor.
Good Luck,
Gil
Feb 28, 2010 | GE PTS25SHS Stainless Steel Top Freezer...
Refrigerator door
ice door won't close ge #pss26msrbss
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Flucuating temps/constant running
yes its very important to have clean coils at the back it will run better
Jul 13, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
1,074 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
