Question about Microsoft Excel for PC
Circular reference working how to open excel file
Circular Reference Warning
One or more formulas contain a circular reference and may not calculate correctly. Circular reference are any refereces within a formula that depend upon the results of that same formula. For example, a cell that refers to its own value or a cell that referes to another cell which depends on the original cell's value both contain circular references.
For more information about understznding, finding and removing circular references, click ok. if you want to create a circular reference, click cancel to continue.
  • 2 more comments
  • amal_kodeh Dec 22, 2008
    Circular Reference and may not calculate correctly. Circular references are any references within a formula that depend upon the results of that same formula. For example, a cell that refers to its own value or a cell that refers to another cell which depends on the original cell's value both contain circular references. For more information about understanding, finding, and removing circular references, click OK. If you want to create a circular reference, click Cancel to continue.
  • Anonymous Feb 27, 2009
  • JULIAN May 11, 2010
    Which version of Excel are you using?
  • Peter Sturniolo
    Peter Sturniolo May 11, 2010
    Which cell (A5, B7, etc), and what is the exact formula in the cell?
I have a value in cell E1 say 2500000. I now enter the formula =E1/1000000 the result is a circular reference. How to remove it ?
Posted on Apr 06, 2010
  • 407 Answers
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Posted on May 22, 2009
Please help me to solve the circular reference in 2013 excel file which stop opening the file. Thank you
first start excel and click on formula tab -->Calculation options -->Manual
excel1-yi4l5i2224qkwob0czw2k0fe-5-0.pngNow open file, if asks for update formulae, say no.
Now select entire sheet, select formulas tab--> Error Checking -->Trace Error.
excel2-yi4l5i2224qkwob0czw2k0fe-5-2.png It will locate all error containing cells, now rectify the error save it reopen in excel to see if problem is solved.
Apr 12, 2017 | Microsoft Excel for PC
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Unable to open EXCELL 2007 workbook containing a circular reference problem.
open Excel
Click the 'Microsoft Office' button and click 'Excel Options'. Click the 'Formulas' button. From 'Calculation options' section, un-select the 'Automatically' option. then use file->open->yourfile.xlsx. It should now open. Find the circular reference and fix it. Then save the file.
Mar 18, 2013 | Microsoft Office Excel 2007 Full Version...
My Excel 2007 status bar shows the words "Calculate" even though my calculation is set to automatic. From my experience with the prior version of Excel, this indicates a circular reference error....
A couple of possible causes:
Setting Workbook.ForceFullCalculation to True will cause this.
The Iteration Option is turned on and the workbook contains circular references. Turn off Iteration (Tools-->Options-->Calculation) and press F9-- it may show "Circular Reference."
Jun 20, 2011 | Microsoft Office Professional 2007 Full...
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Can't reopen circular reference file in excel
  1. Click the Microsoft Office Button , click Excel Options, and then click the Formulas category.
  2. In the Calculation options section, select the Enable iterative calculation check box.
  3. To set the maximum number of times that Excel will recalculate, type the number of iterations in the Maximum Iterations box. The higher the number of iterations, the more time that Excel needs to calculate a worksheet.
  4. To set the maximum amount of change you will accept between calculation results, type the amount in the Maximum Change box. The smaller the number, the more accurate the result and the more time that Excel needs to calculate a worksheet.
Nov 05, 2008 | Microsoft Excel for PC
Circular reference errer in excal file in office 2007 Problem. when i open excal seet and whant to change and save. then pc show problem? ple help me shamsherpatel
Hi shamsherpate
In order to remove this error message you need to locate and remove the incorrect references:
On the Formulas tab, in the Formula Auditing group, click the arrow on the Error Checking in-group button, point to Circular References, and then click the first cell listed in the submenu.
Tip You can move between cells in a circular reference by double-clicking the tracer arrows.
Review the formula in the cell. If you cannot determine whether the cell is the cause of the circular reference, click the next cell in the Circular References submenu.
Note The status bar displays the word "Circular References" followed by a reference to one of the cells contained in the circular reference.
Continue to review and correct the circular reference until the status bar no longer displays the word "Circular References."
Regards,
TheAssembler
Jun 06, 2008 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
1,311 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
