Question about Philips 105S51 15" CRT Monitor
Crt not working
I have a philips 105s5 crt monitor.when i turn it on there is a blank screen but the green light is on. i know it's a problem with the power since when i fiddle with the cable behind the monitor it fliks on for a second or two. i replaced the cord but the problem persisted. can anyone help?i cant really get a new monitor as this ones just about 5 months old.
I am a monitor technicians i think it is a high voltage shut down most likley is a failure if one or more of electrolicy capacitors in the primary and secondery sides of smps transformer if you know what i am talking about you can fix it
Posted on May 14, 2007
  • 624 Answers
Mr fool, Hope I?m not too late but if it?s only five months old you should contact the manufacturer?s technical support immediately. Most computer equipment has a one year warranty and a failed power socket or connection would definitely be covered. If you open the LCD case and try to repair it you will void the warranty. Let us know if you have any more questions and please don?t forget to rate the posting.
Posted on Jan 23, 2007
    Scholar:
  • 168 Answers
Well it seems that there is a loose connection inside (cold solder) especially the power supply circuits. try to open it and inspect if there is a bad solder and resolder it. good luck!
Posted on Jan 21, 2007
  • 4 Answers
I have a really old monitor that does the same thing. give it a good whack on the side.
I have a Philips 105S5 15" monitor and its OSD is
"OSD Lock" is the On Screen Display Lock, a feature designed to prevent you from accidentally changing any of the settings of the monitor. To disable the OSD lock, press and hold the menu button for 10-15 seconds.
Dec 30, 2010 | Philips Standard 105S Monitor
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
May 27, 2009 | Philips Computers & Internet
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor is blank but green light is on
if you disconnect the data cable while the monitor is on, you should get a red and cyan message telling you to check the cable, that assures you that the problem does not coming from the monitor, instead check th video card.
Jan 23, 2008 | HP Pavilion M70 17" CRT Monitor
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Blank monitior
There is probably some electronic malfunctions inside your monitor. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem. Problems regarding inside the monitor are usually not fix-it-yourself kind of thing for non-expert like you compared to software problem, which can be mostly fix by yourself guided by an expert.
Sep 12, 2006 | HP Pavilion MX70 17" CRT Monitor
Philips 105S51 15" CRT Monitor Logo
177 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
