Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer stops for no reason.
Whirlpool Heavy Duty Large Capacity 6 cycle 2 speed
The washer stops at any point mid-cycle, then starts again..sometimes. We push the dial in, then out to restart cycle.
    President:
  • Whirlpool Master
  • 2,651 Answers
I would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Posted on Nov 20, 2008
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Water will not stop when level is reached but starts next cycle
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
Aug 22, 2009 | Washing Machines
Jammed agitator
Some further checking indicated a bad transmission. As the unit is 15 years old, I decided the best solution was a new machine! ..
Dec 03, 2008 | Washing Machines
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
231 people viewed this question
Dan Webster
Dan Webster
Sal De
