Question about Sony Playstation 3 (PS3) Console
Screen has has horizontal white lines and a loud buzz with ps3.
When the ps3 it plugged into the television using the rca plugs, there  is a loud buzz and horizontal white lines that slowly move up the screen. the problem happens whether or not the system is turned off at the back, in standby, on the home screen and during game play. two days ago i was playing on a high def sony using an hdmi cable and there was no problem. ive plugged it into several televisions using the rca cables and the problem is the exact same. the system functions 100% normal besides this. please help im desperate.
  • 1 more comment
  • matt_rides_p Nov 20, 2008
    thanks for the idea but i have tried two separate playstation rca cables and the problem has persisted.
  • Anonymous Dec 11, 2008
    I have the same problem of horizontal lines slowly progressing up the screen.
  • Anonymous Feb 10, 2009
    i also have the same problem and i cant figure it out. i just got my ps3 a few days ago. the buzzing noise is so annoying!
  • 98 Answers
It could be that your rca cables are damaged, you can try using different ones, or it could be that you have a setting to use rca cables turned off in your settings of the ps3.
Posted on Nov 20, 2008
Just got this tv from friend. has no remote. screen is black. sound is good. when you push menu button, white line goes across horizontally the screen.
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
Jan 05, 2011 | RCA F25442 25" TV
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
Slow moving lines up screen
I noticed the same lines on my 32" Sylvania LCD. After playing with some electrical plugs, I found that having my Sony PS3 plugged in interfered with my cable quality. When I unplugged the PS3, the lines and slight humming (only noticeable from behind TV) went away. I tried making sure the cable line and PS3 power cord weren't touching but to no avail. I guess I'll just leave in unplugged while watching TV.
Dec 03, 2009 | Sony Televison & Video
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Lines on the screen
Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
Jun 07, 2008 | Sony Playstation 3 (PS3) Console
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Buzzing sound
the horizontal output is shorted ,has to be replaced BUT solder all connections for three inches around the this horizontal and solder them well or the output will blow again,there is especially a small coil in the drive line to the base that causes most of the problem
Oct 05, 2006 | RCA 27F530T 27" TV
Screen displays Horizontal white lines
try adjusting the screen control down..if this has no control unit may have a bad video drive circuit or possible bad crt or fly back transformer ...just a wag
Feb 06, 2006 | RCA F36649 36" TV
Sony Playstation 3 (PS3) Console Logo
212 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
