Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
Motorola Talkabout T5500 Menu button doesn't work
I can't get the menu button to work. No matter how long I hold it down, the menu won't lock, flash the channel numbers or anything. I am stuck on channel 1-1.
  • 123 Answers
I think you radio has a problem and will need to be checked, rapaired or replaced.
Posted on Dec 16, 2006
    New Friend:
I fixed a similar defect on the menu button of my Motorola T5500 by pressing it repeatedly many times. It worked again.
Posted on Mar 27, 2015
Can I turn off the beep on the cxt195?
You mean the "roger beep"? You can try the steps below from this site>>http://science.opposingviews.com/turn-roger-beep-off-motorola-walkie-talkie-10001.html
Step 1
Turn the Motorola Talkabout two-way radio on by pressing the "Power" button.
Step 2
Hold down the "Menu" button for several seconds until an icon appears on the screen. "On/Off" begins to flash on the screen.
Step 3
Press the "Minus" button to turn the "Roger" beep off. If you want to turn it back on, press the "Plus" button.
Step 4
Tap the "PTT" button to save the change. You may also press "Menu" to save the change and completely exit Menu mode
Hope it helps...
Dec 03, 2014 | Radio Communications
Motorola Talkabout t5000 sold at Costco (several years ago) with a mini T4500. An insert was included so the mini could talk to the others. It says to hold the menu button down and then select 0 for the...
Your frequency and your code are two separate settings. When you walk your way through the menu the frequency choice will come before the code choices. Frequencies will count from 1-14 or 1-22. Codes (aka interference eliminator) will have may more choices and one of them will be Zero. It appears from looking at the T4500 manual that it does not offer "code". So on this one the code is already "zero" (off). On your T5000 you should be able to navigate to the CODE using the menu button, then use your plus or minus button to get you to "zero", then press the PTT button to save your choice.
Best regards.
Our first thought when reading your dilemma is to check the Menu Lock. Holding the Menu button in for 3 seconds will lock/unlock your buttons. You should have an icon depicting a lock displayed on the screen.
Aug 17, 2013 | Motorola T5000 Two Pack 2-Way Radios with...
Can't get FV300 to power up
You can find a copy of the user guide at: shop.giantintl.com/Manuals.asp
The power/menu button will turn the radio on/off by holding it in a long press. Once the radio is on this same button acts as a menu button when pressed a short press.
Best regards.
Jun 14, 2013 | Motorola Talkabout FV300 Two Way Radio
Problems setting the Interference eliminator code for a Motorola MR350 Talkabout
Holding in the MENU a long press will turn the LOCK on or off. You will need the menu unlocked for the following...
However, if you press the MENU button repeatedly, not holding it in a long press, you will walk through all the menu items, and there you will see when the CODE number begin to flash. You will also see setting for other features as you walk though the menu. Refer to your manual for these settings.
http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Jul 18, 2012 | Motorola Talkabout Mr350r 2 Way Radio
How can i shut the beep off when the button is keyed
Holding in the plus (+) button while turning on the TalkAbout radio will turn on/off the "roger beep" on most models.
Nov 04, 2009 | Motorola Talkabout T5500 (7 Channels)...
Unlocking problem
you might just need to press it harder
Nov 22, 2008 | Motorola Talkabout T5500 (7 Channels)...
Motorola talkabout 250
Hold one of the side buttons on and turn the radio on. This will put you in a menu mode. use either the ptt button or a control button on the front to scroll up or down either of the 2 menus once you find the vox selection. using one of the other buttons to turn it on or off
Jul 17, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola T5500 - can't start scan !
Hello AHAPXUCT,
To start scanning on a Motorola TalkAbout T5500 all you have to do it press the MON button for a full second and then release it. The radio should automatically being scanning the channels for activity and stopping on any received signals.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 10, 2008 | Motorola Talkabout T5500 (7 Channels)...
Turning off distinctive end broadcast chirp on motorola 2 way radios
i have the t5600 pair and have found no way to do it but you can hold the menu button in for 3 to 5 seconds and open your selection menu that includes lock,tones,etc and on your model you may be able to turn it off. good luck!!!
Dec 13, 2007 | Motorola Talkabout T5400 (14 Channels)...
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
354 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
