Question about Amana ARB220RCW Bottom Freezer Refrigerator
Fridge/freezer not very cold and cylinder is very hot? amana arb220zcw
    President:
  • Amana Master
  • 2,651 Answers
Souns as if youre having an issue with your compressor("cylinder?") black football sized motor behind unit???5 yr manufactures warr if so, cross your fingers, out of warr that repair could cost 4-6 hundred dollars
Posted on Nov 20, 2008
Frig not working freezer is great
If your fridge is old you maybe have a leak, crack, blockage in the fridge part...or at first step check your temp controls ...should be knobs in freezer as well as in bottom of fridge...sounds simple but overlooked at times. If fridge is a n older model especially if its located in a hot room it takes alot of freon and at times they are not equipped to get cold in extreme hot storage temps.
Jul 07, 2012 | Amana Refrigerators
Fridge door seals are hot fridge not cold
The door seals get hot so they don't stick to the cold metal. Check and clean the outside parts; one looks like a sort of radiator. Make sure this is clear.
Apr 02, 2012 | Amana Refrigerators
The freezer door handle on our ARB220ZCW is cracked. Where can I get a replacement?
I have used this site for a couple of replacement parts for both refrigerator and dish washer and have been extremely satisfied with their service. Hope it helps
http://www.partselect.com/
Nov 29, 2010 | Amana ARB220RCW Bottom Freezer...
Amana model arb220zcw is not cooling. Freezer and
Your problem could be one of two issues.
- The relay part number 12555902. This is a package that plugs directly onto the compressor, it is an easy repair.
- If the relay does solve the problem the issue is the compressor itself. This repair is major and usually will cost around $500.00 and will need to be done by a professional
Apr 18, 2010 | Amana ARB220RCW Bottom Freezer...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana side by side fridge model sxd22s2l freezer/fridge not cold
they can get up to 305 degree F they can make brown spots on floor... yes they get very hot(is normal)
Aug 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Hi, my amana freezes my food in the refrigerator....
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..It may be stuck open letting in too much cold air.
Aug 15, 2009 | Amana Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water from core is getting into my freezer
Right, the drip tray on the upper coil section has a blockage (possibly mold) that prevents the defrost condensate from reaching the evaporator pan that should be at the bottom of the fridge. Those lines are usually accessed from the back of the fridge.
Jun 19, 2008 | Amana ARB220RCW Bottom Freezer...
Amana ARB220RCW Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
